url action with parameter
    Trying to adjust my volume via tuneblade's API... this string works from curl:
    curl -X PUT -H "Content-Type: application/json" -d "{\"Status\": \"Connect\", \"Volume\": 5}" http://touchpanel:8081/Master
    I want to use dimmer to set the parameter field so I was thinking this but think I have a formatting issue:
    Sub Main(Parm As Object)
       Dim ParmArray() As String
        dim result as String
        dim website as String = "http://touchpanel:8081/Master"
        dim request as String = "PUT"
        dim information as String = "{""Status"" : ""Connect"",""Volume"" : ParmArray()}"
        dim header as String = "Content-Type: application/json"
        result = hs.URLAction(website, request, information, header)
    End Sub
    THanks in advance.
    Are you asking how to set the parameters you put in the script into the data?
    You can try
    dim information as String = "{""Status"" : ""Connect"",""Volume"" : " & Parm.ToString & "}"
    If you are passing in a simple string...
      Also I'm trying to use TuneBlade, can anyone help me?
        I just released a TuneBlade plugin to provide HS3 devices for each connected speaker for volume and connection control in case you're interested!
