Our new 200 series wall switches will debut at CES 2018 next month. The new switches are equipped with RGB LED indicators that can be controlled with Z-Wave commands.
In "normal mode", LEDs can be set to your color preference and will reflect the status of each local load (on-off-dim level). Don't like blue? Change to White, Red, Green, Magenta, Cyan or Yellow. Want to 'jazz up' your routine? Change colors every day or just during holidays, birthdays and special events.
When a Z-Wave command is sent to control an individual LED, the switch will change to "status mode" and will glow or blink the color of your choice. Did you leave the garage door open after midnight? Have the 3rd LED blink red in the bedrooms. Did you forget to lock the side door? Have the 5th LED glow yellow. Did the smoke alarm go off downstairs? Have all the LEDs on all switches blink Magenta. Switches will stay in status mode until you send and 'off' command to reset them.
The new dimmer and switch begin shipping in January. The fan controller will ship in April.
Full press release: http://www.prweb.com/releases/2017/12/prweb15042437.htm
Dimmer product page: https://shop.homeseer.com/products/h...gb-wall-dimmer
