I have an RGB LED strip that runs firmware with MQTT support. Homeseer supports a "color picker" control but it is apparently only available if the device is created via a plugin - can't be set manually, even though it is an option.
Could it be as simple as adding a checkbox to the interface to make the created homeseer device have this option? If so, that would be great!!
Thanks - love how easy this plugin is to use. Very intuitive!
