I guess not - I assumed updating the plugin actually started running the updated version. Manual stop/start definitely had an impact.
Unfortunately, the first observation is it appears to have orphaned the devices it previously created. In the setup, their associate boxes are unchecked, and checking them created a second identical-looking device.
Next was it didn't appear to like that debug was enabled and there was already a debug text file. Restarted the plugin a couple times and still only had the tail from the shutdown in it. Renamed that file then restarted and it seemed happy again.
So, I'm now seeing a hex color on the left side of the device, but it doesn't change when I make a change with the color picker. It appears that the STRING is being set on device creation, but not updated when the VALUE changes, which seems to be working as intended. Progress?
Attached image shows after the debug log below.
6/28/2018 11:49:00 AM 585627 | SetIOMulti 758, oCAPI.ControlType=Color_Picker 6/28/2018 11:49:00 AM 585632 | Update Accepted 758 to ##FFFFFF StatusType=5 6/28/2018 11:49:00 AM 585653 | Updating Device from 16711680 PayloadNumeric=False 6/28/2018 11:49:00 AM 585656 | RGB ##FFFFFF is not valid format, saved as 0 6/28/2018 11:49:00 AM 585663 | ActoOnMessageFor Trigger Topic ESPURNA_BASEMENT/rgb/set,Payload=##FFFFFF 6/28/2018 11:49:00 AM 585689 | ActoOnMessageFor Trigger Topic ESPURNA_BASEMENT/rgb,Payload=#000000 6/28/2018 11:49:00 AM 585747 | ActoOnMessageFor Trigger Topic ESPURNA_BASEMENT/hsv,Payload=0,0,0 6/28/2018 11:49:00 AM 585805 | ActoOnMessageFor Trigger Topic ESPURNA_BASEMENT/brightness,Payload=255 6/28/2018 11:49:00 AM 585863 | ActoOnMessageFor Trigger Topic ESPURNA_BASEMENT/mired,Payload=153 6/28/2018 11:49:00 AM 585872 | ActoOnMessageFor Trigger Topic ESPURNA_BASEMENT/channel/0,Payload=0 6/28/2018 11:49:00 AM 585880 | ActoOnMessageFor Trigger Topic ESPURNA_BASEMENT/channel/1,Payload=0 6/28/2018 11:49:00 AM 585888 | ActoOnMessageFor Trigger Topic ESPURNA_BASEMENT/channel/2,Payload=0 6/28/2018 11:49:00 AM 585895 | ActoOnMessageFor Trigger Topic ESPURNA_BASEMENT/channel/3,Payload=212 6/28/2018 11:49:00 AM 585902 | ActoOnMessageFor Trigger Topic ESPURNA_BASEMENT/channel/4,Payload=0
