  #161
Old December 9th, 2017, 06:32 PM
mrhappy mrhappy is offline
OverSeer
Quote:
Originally Posted by huntley1 View Post
That command window does not pop up. Do I have to be connected to the controller directly? I using the web server from my laptop
Yes unfortunately you do, do you have access to the HS directory to open a config file? If so could you PM me the contents of your DoorBird3P.ini file in the config directory and I will take a look at the contents.
  #162
Old December 10th, 2017, 11:31 PM
huntley1 huntley1 is offline
Seer Deluxe
I connected to the controller directly and was about to send you a screen shot of the setting. I noticed the password was not correct and something told me to try the settings again now that I'm directly connected to the controller. I entered in the username and password and it accepted that. For now everything seem to be working
  #163
Old December 11th, 2017, 09:50 AM
OverSeer
Good to hear it is working, it still should be OK setting it remotely but guess it is just a gremlin. Let me know if you have further issues but it should be fine once you include it once.
  #164
Old January 21st, 2018, 05:28 PM
deanrparry deanrparry is offline
Seer Deluxe
Refresh
Checking the images in html/images/DoorBird/ and i can see they only refresh to the very latest versions of d1.jpg and m1.jpg when you actually go to HomeSeer GUI and click into the DoorBird plugin and view it.
Only then do those 2 images refresh themselves
Could you get these to refresh without any intervention from a user so they can be used in HSTouch please?
Even if i use the history with date and time in an event and pass it to hstouch that is still the older version of the image by 1.
Many thanks,
Dean
  #165
Old January 22nd, 2018, 05:24 AM
OverSeer
Many thanks,
Dean
The images in this directory are what is downloaded from the DoorBird device, the device stores an image when the doorbell is pressed and the plugin is downloading this image from the device but is only doing it upon request from the UI as you found. Even I were to refresh the download they still are the images stored in the unit, not always a live image.
Can you show me what you are doing in an event, it could be that when you are downloading the image (say when the doorbell is pressed) that the image has not get finished being saved to the unit so is old (I had to put something in to deal with that as if you read too quickly you got half an image) by one. A delay/wait of a couple of seconds may solve that.
  #166
Old January 23rd, 2018, 07:24 PM
Seer Deluxe
Thank you kindly... even a 1 second delay is sufficient and we have a snapshot of who is at the door at last
  #167
Old February 25th, 2018, 07:47 AM
OverSeer
Does everyone's plugin still work OK? DoorBird have very kindly put significant changes in their API but appear to have got rid of some old methods that I was using in the plugin (which from what I can see make no mention of whether or not they continue to support them or they have gone) and I don't know if this has had any implications on how things are working.
  #168
Old February 25th, 2018, 08:08 AM
Seer Deluxe
Worked 12 hours ago if that's helps? Delivery of my Chinese takeaway yum yum
  #169
Old February 25th, 2018, 08:27 AM
stefxx's Avatar
stefxx stefxx is offline
Seer Master
Still seems to work for me as well. Great plugin!
stefxx
  #170
Old February 26th, 2018, 01:54 PM
stefxx's Avatar
Seer Master
I spoke to soon. Since a restart of HS3, it doesn't work anymore...
feb-26 08:00:21 DoorBird DoorBird Web Exception: The request was aborted: The operation has timed out.
feb-26 07:56:21 DoorBird DoorBird Web Exception: The request was aborted: The operation has timed out.
feb-26 07:54:21 DoorBird DoorBird Web Exception: The operation has timed out
feb-26 07:50:21 DoorBird DoorBird Web Exception: The request was aborted: The operation has timed out.
feb-26 07:48:21 DoorBird DoorBird Web Exception: The operation has timed out
feb-26 07:46:21 DoorBird DoorBird Web Exception: The operation has timed out
feb-26 07:26:18 DoorBird DoorBird Web Exception: The remote server returned an error: (500) Internal Server Error.
feb-26 06:58:21 DoorBird DoorBird Web Exception: The request was aborted: The operation has timed out.
feb-25 19:50:14 DoorBird DoorBird MAC Address: xxxxxxx
feb-25 19:50:14 DoorBird DoorBird Build Number: 15190330
feb-25 19:50:14 DoorBird DoorBird Firmware: 000110
feb-25 19:50:14 DoorBird Success At Connection To DoorBird
feb-25 19:50:14 Starting Plug-In Plugin DoorBird started successfully in 38 milliseconds
feb-25 19:50:14 Starting Plug-In Initializing plugin DoorBird ...
feb-25 19:50:11 Info Plugin DoorBird has connected. IP:127.0.0.1:61444
feb-25 19:50:11 Plug-In Finished initializing plug-in DoorBird
feb-25 19:50:09 Plug-In Found plug-in: DoorBird, version: 0.0.0.19
And now only this:
feb-26 18:52:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
feb-26 18:50:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
feb-26 18:48:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
feb-26 18:46:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
feb-26 18:44:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
feb-26 18:42:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
feb-26 18:40:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
feb-26 18:38:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
feb-26 18:36:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
feb-26 18:34:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
feb-26 18:32:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
feb-26 18:30:16 DoorBird DoorBird Web Exception: The remote server returned an error: (503) Server Unavailable.
  #171
Old February 26th, 2018, 04:08 PM
Seer Deluxe
restarted homeseer here and doorbird still works
  #172
Old February 26th, 2018, 04:11 PM
OverSeer
And now only this:
Strange, what is odd is that I would expect it to return a 404 error (or similar) if I was calling something that no longer existed however as this is returning 503 it seems like it can't reach it at all but at the start it manages to connect and get the data from the unit. Can you just try restarting it a couple of times and seeing if anything changes?
  #173
Old February 26th, 2018, 04:30 PM
stefxx's Avatar
Seer Master
After some basic troubleshooting, it seems my device is having problems. The video stream was still accessible, but I could not login to the admin section (from the Doorbird app).
I restarted the device, and I can non-stop ping the device without issues, but the video access from the device fails most of the time. Is my device broken?
  #174
Old February 26th, 2018, 04:33 PM
OverSeer
I'd leave it a short time and try again, it might have left some video connections open and waiting for them to time out. You will get a 503 if you have more than one open at a time...
Quote:
Please keep in mind that the device is a Video Door Station, which handles in general - like all commercially relevant door stations - only one simultaneous audio/video call for live communication. You get a status code "503" (Busy) if another user already took the call. In that case you can notify the user with a message dialog on your GUI, e.g. "Line busy" and additionally preview one still image (LIVE IMAGE REQUEST)
  #175
Old February 26th, 2018, 04:41 PM
stefxx's Avatar
Seer Master
Thanks. I posted my message after 10 minutes of trying, and just two minutes later it started working again
Plugin is working as well again. Not sure why it failed for over 24 hours... but it seems resolved. Thanks!
  #176
Old March 24th, 2018, 02:39 PM
OverSeer
DoorBird look to have made some significant changes to the API with their D2xx line of devices, I imagine (and hope for my sake) that the use of these devices is going to be rare to non-existent with HS users due to the fact that they are likely more suited to commercial applications where multi user access is required. Support for these devices on this basis will be limited at this time. There is no information in the DoorBird API as to when they are likely to deprecate the old legacy HTTP calls and I have decided to go through the pain of changing now rather than get caught by surprise later.
Some changes I have noticed/implemented;
1) The relaxation parameters have gone, these were the re-trigger times for the sensors - albeit there appears to be a setting in the app called 'pause between alarms' which may do the same. All mention of that and ability to change those parameters has gone from the plugin.
2) Moved to Newtonsoft JSON DLL, users won't notice this and it was needed because the .net functions don't have the flexibility around some parameter properties that Newtonsoft has.
3) Users can have the ability to be able to be designated an API operator - I HIGHLY suggest you ensure that the user that you are using in the DoorBird plugin is afforded these permissions in the app.
4) Favourites/Schedules - The biggie! DoorBird have made some decisions here that again will likely not be used by HS users. The way I setup the plugin is to create three favourites which are the HTTP calls into the plugin to notify HS of your doorbell/motion/open sensor being triggered. You then have to set a schedule for these favourites to be activated, these were a bit problematic to preserve so I have elected that they be defaulted to 24x7 for both alert notifications to the DoorBird service and also to the plugin. HS's event engine is going to be better to make decisions around the timing/conditions of when events should be triggered and it could cause confusion should these schedules be amended in the app.
I am afraid visually there is nothing different and as such it might be difficult to notice the changes, I would be greatful if someone would be willing to give version .20 a go for me and see how they get on (I am more interested in whether it works and newer functionality should hopefully be coming at some point) - this zip file can be extracted into your HS directory and then go into the updater and it uses the updater_override file which you will need to delete afterwards.
Thanks...
  #177
Old March 26th, 2018, 04:45 PM
stefxx's Avatar
Seer Master
I installed .20 on my HS3 system running build 423. I am using a D101S DoorBird device with firmware 110.
A (very) quick test seems to validate that everything is working just fine. If over the next few days anything happens you'll be the first to know
Thanks for your continued support!
  #178
Old March 26th, 2018, 07:29 PM
mwolter mwolter is offline
Seer Deluxe
Well, shoot. Hope this doesn't break things, I have a D202. Got a good deal on it I'll try the new plugin shortly and let you know.
  #179
Old March 27th, 2018, 12:24 PM
OverSeer
That's good to hear thanks I'll wait to hear back from a couple of other people to make sure it's ok then I'll put it in the updater. Thanks for trying it..
  #180
Old March 27th, 2018, 12:36 PM
OverSeer
Quote:
That's great to hear and the D202 should be ok as it's just a single access intercom, it's more the multi button ones that support is limited for at the minute.
HTML code is Off
Doorbird (Video Doorbell) Plugin Request skarragallagher HS3 Plug-In Development 41 July 9th, 2016 05:51 AM
DOORBIRD Eman Tasker Plugin (3P) 1 May 6th, 2016 03:34 PM
Beta to Release beerygaz Modbus Plug-In 8 February 8th, 2016 08:48 AM
BETA Release 1.1.1 twa8000 TWA-Onkyo / Integra Plug-in (3P) 44 December 14th, 2010 04:43 AM
