No response/improper response from Elk M1 to command 'st10x'
    Hello all....
    I am getting this error in my log. They are always either ST101, ST102, or ST103.
    Any ideas what this means?
    CT
    5/19/2007 10:48:35 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:48:37 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:48:38 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:48:40 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:48:41 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:48:43 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:48:44 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:48:46 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:48:47 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:49:35 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:49:37 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:49:38 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:49:40 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:49:41 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:49:43 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:49:44 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:49:46 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:49:47 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:50:35 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:50:37 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:50:38 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:50:40 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:50:41 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:50:43 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:50:44 PM Database Item Saving Event UnNamed
    5/19/2007 10:50:44 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:50:46 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:50:48 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:51:35 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:51:37 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:51:38 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:51:40 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:51:41 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:51:43 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:51:44 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:51:46 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:51:47 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:52:24 PM Database Item Saving Event Garage Rear Door Light On
    5/19/2007 10:52:35 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:52:37 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:52:38 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:52:40 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:52:41 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:52:43 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:52:44 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:52:46 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:52:47 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:53:12 PM Database Item Saving Event Garage Rear Door Light On
    5/19/2007 10:53:35 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:53:37 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:53:38 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:53:40 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:53:41 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:53:43 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:53:44 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:53:46 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:53:47 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:54:35 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:54:37 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:54:38 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st101'
    5/19/2007 10:54:40 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:54:41 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:54:43 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st102'
    5/19/2007 10:54:44 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:54:46 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    5/19/2007 10:54:47 PM UltraM1G Warning No response/improper response from Elk M1 to command 'st103'
    Evening...
    I gather you have the newer KP2 only on your system and not the older KP1. What the plugin does is check for the temperature reading on the keypads to make sure it can properly talk to the ELK
    st=give me the status in ascii
    10x= where x is the keypad number
    Possibly Ultra is going to have to change this as not everyone is going to have the older KP1 on their system ( I do).
    Cheers..Pete
    HS 2.2.0.11
      Ahh...that makes sense. I have three of the new keypads and one of the older model. BTW, it is too bad that they could not include the temp in the newer models. Oh well.
      Thanks for the feedback....
      CT
        I have family in town, so I won't be able to get to this till later this afternoon.
          CT
          CT, the quick way around this then is to change the ID's on your keypads to put the older keypad into either ID 1, 2, 3
          I noticed ULTRAs code only looks for those as having TEMP capability
          CHeers..Pete
          HS 2.2.0.11
            Hi -
            I'm getting the same error codes. I also only have a KP-2 keypad. In looking at the HS Updater it looks like I have the most recent UltraM1G plugin. Currently I have to restart HS every day in order to get this to stop. Any timeline on an update to fix this?
            Pat
              Hi Beerguy
              Understand its annoying, I like to have clean logs however it wont hurt your HS installation for the moment....
              Pete
              HS 2.2.0.11
                As a work-around, delete the HomeSeer device associated with that keypad. It shouldn't attempt to get the temperature from it if the HomeSeer device doesn't exist.
                  Thanks for the help. As long as it doesn't impact the functionality I'm good with waiting for the fix.
                  Pat
                    Hi -
                    Any update on the fix for this? I tried deleting the device but that didn't seem to stop the polling. I'm also not certain that this isn't slowing response time.
                    Pat
                      I plan on posting the update tomorrow. Thank you for your patience.
                      Note: The update requires M1 version 4.3.4 or greater.
                      Ultrajones
                        Ultra
                        To get the output names above 32, you already need 4.4.x and the latest Ethernet Expander firmware so I would suggest anyone playing extensively with your plugin, upgrade their firmware to the latest available...
                        Pete
                        HS 2.2.0.11
                          beerguy,
                          The version I just posted to the HomeSeer updater should resolve the temperature query issue when using the KP-2 keypads. Please let me know if it works ...
                          Ultrajones
                            Hi Ultra
                            How are you cheking for status now instead of testing the temp sensor on the KP ? Nice to know as if we see future issues, we can help ourselves...
                            Cheers..Pete
                            HS 2.2.0.11
                              So far this seems to be working great. No more errors in my log file.
                              Thanks much for updating it.
                              Pat
