Go Back   HomeSeer Message Board > Legacy Software & Plug-ins > Legacy Plug-ins > Legacy 3rd Party Plug-ins > TWA-Onkyo / Integra Plug-in (3P)
TWA-Onkyo / Integra Plug-in (3P) Discussion for TWAOnkyoInegra plug-in.
Old November 9th, 2010, 02:15 AM
twa8000 twa8000 is offline
BETA Release 1.1.1
BETA RELEASE 1.1.1
- Fixed Max Volume Device Filling Logs because Zone 2 and 3 Not On
- Fixed Certain Devices not working with Events
- Fixed an error that occurs during device creation
- Added Device XM & SIRIUS CATEGORY
Please report bugs, Thanks
-Tom-
File Type: zip HomeSeerPluginTWAOnkyoIntegra_1_1_1.zip (442.5 KB, 26 views)
Old November 9th, 2010, 04:31 PM
richardo's Avatar
richardo richardo is offline
Tom,
Thank you for the latest beta. - I installed 1.1.1 this evening, but still cannot connect using TCP/IP (I am connected through the serial port).
Thus far I have changed nothing - just installed the new beta- everything else works fine.
Is there any debug info I can offer?
the past is from where we learn....
Old November 9th, 2010, 11:56 PM
Originally Posted by richardo View Post
Tom,
Yes u could provide a debug log of it connecting and/or adjust the delay in the config to 2000, that is a large delay, but I'm curious to see if that would work, I also recommend checking the ip settings in the receiver to make sure you have the correct address and that the port is turned on, is it a static or dynamic ip and also try doing a hard reboot of the receiver, unplugging power and Ethernet cable, then plugging in and then plugging in the Ethernet cable, I know if the receiver had a connection before and it was lost sometimes it had to be reset, this was an issue with mine, also just try changing ur receivers ip
Also are there any free onkyo software on the Internet used to control the receiver, I've seen a few before, just curious if those work
-Tom-
Old November 14th, 2010, 12:50 PM
manxam manxam is offline
Tom, I'm still having the same issue as with the original plugin where it's not properly detecting the off state of my receiver.
The plugin will always detect then the receiver is turned on whether remotely or via the plugin but MOST of the time will not update the off status accordingly. If using the plugin I can use the "power standby" button 3-4 times and, while the receiver turns off, the plugin thinks it's still on. This also occurs when operating the receiver remotely. The only way for it to update the status is to use the "poll receiver" link in the plugin setup.
As you mentioned previously, I had a script setup to poll the receiver once a minute but that functionality appears to have been removed from this beta as I get the following error:
Running script, init error: Object doesn't support this property or method: 'hs.Plugin(...).PollUnit'
Any help in diagnosing this issue would be greatly appreciated.
Cheers!
Old November 15th, 2010, 04:19 AM
Cheers!
I dont know if you read my note on the other BETA, but you have to delete your power devices and rerun create devices...
Yes the pollunit command is different in the new version since it was never officially supported.. ill have to figure out the call
Are you using TCP/IP or Serial?
-Tom-
Old November 15th, 2010, 04:27 PM
Tom, I fully uninstalled your old version, deleted the devices, and reinstalled. I then let the plugin poll and recreate all devices. As stated above, the plugin power buttons and evens generated with them work a) ALWAYS for ON and b) SOMETIMES (less often than more) for OFF
This existed with all of your plugins since the original betas.
I'm using serial and have scripts that I've written for HS that work properly and scripts with Eventghost that also works so I know it's not the cabling.
Cheers,
Mark
Old November 16th, 2010, 04:18 AM
Cheers,
Mark
It's has to be a timing issue, in the config increase the send delay real high to see if it resolves the issue, set it at like 3000 just to test
-Tom-
Old November 16th, 2010, 06:12 PM
I've increased the delay to 3 seconds and I'll play with it when I get home; will keep you apprised.
Mark
Old November 19th, 2010, 02:25 AM
Unfortunately that didn't work. While the remote turns off the receiver, the plugin (most often) still thinks the receiver is on.
I then hit the "power standby" button in HS several times before the plugin determines that the receiver is off. If I poll the device, it detects the change in state and updates accordingly.
Any idea why the plugin isn't detecting the state change ONLY on power off?
Mark
Old November 22nd, 2010, 12:44 PM
Mark
Sometime when u send a command from the status page, the page refreshes before the receiver sends a signal back saying the status is updated, Maybe try refreshing manually after turning the unit off to see if it actually updated or not, Also try turning on debug mode and see if the plugin is receiving the off/standby command...
-Tom-
Old November 23rd, 2010, 01:11 AM
Tom, refreshing the page does not help and any events that should be generated by "power standby" don't. I have debug enabled and it's not showing a power off from the receiver when I manually turn it off. When using the button in HS it shows the command being sent but doesn't confirm response.
Keep in mind that this occurs about 50% on power standby but that power on works 100% of the time.
The ONLY reason for my purchasing this plugin is to turn on/off the projector and subwoofer(s) when the receiver turns on/off. Unfortunately this isn't working reliably.
Also, the removal of the ability to poll the receiver from an event was somewhat of a backwards step as this, at least, increased the reliability of the event generation.
Any help would be greatly appreciated.
Cheers,
Mark
Old November 23rd, 2010, 01:26 PM
Cheers,
Mark
I understand your frustration, as for the poll command, that was never officially supported in the docs, i kind of just told you about that in the message board here, i can add that back into though next version,
I am at a lost really unless there is a way i can hook up to your receiver to do some error checking, There is a thread that is always checking for commands, and before the command is ever processed it shows up in the log as RAW DATA, do you at least have that showing up when the plugin receives the command? If not it seems the receiver is not sending it? Any chance you are connected through an edgeport?
Old November 28th, 2010, 01:55 AM
Tom, I finally got a chance to do a debug log. It appears that the plugin isn't fully capturing the PWR00 and instead is just seeing it as RW00. I can repeat this 60-70% of the time.
The following debut shows me :
1/ turning off the receiver with a remote
2/ hitting the 'power standby' button in HS twice in hopes that it will update the status
3/ finally using the "poll receiver" button in order to fix it.
11/27/2010 10:48:41 PM 	NO ECHO 	Power Off for TWA_ONKYOINTEGRA Power Control; Power On (3 days, 1 hrs, 3 mins, 33 secs)
11/27/2010 10:48:41 PM 	Device Control 	Device: Z-Wave Interface Subwoofer Power (Q2) OFF
11/27/2010 10:48:41 PM 	Event 	Event Trigger "Subwoofer Off"
11/27/2010 10:48:37 PM 	TWA_ONKYOINTEGRA 	Debug Mode Disabled
11/27/2010 10:48:34 PM 	TWA_ONKYOINTEGRA 	Receiver 1 Polling Unit
11/27/2010 10:48:27 PM 	TWA_ONKYOINTEGRA 	DEBUG MODE: Receiver 1 Command Sent(PWR00)
11/27/2010 10:48:27 PM 	TWA_ONKYOINTEGRA 	DEBUG MODE: Receiver 1 Command Found in Queue(PWR00)
11/27/2010 10:48:22 PM 	TWA_ONKYOINTEGRA 	In ButtonPressEx for TWA_ONKYOINTEGRA Power Control, button pressed is Power Standby
11/27/2010 10:48:14 PM 	TWA_ONKYOINTEGRA 	DEBUG MODE: Receiver 1 Command Sent(PWR00)
11/27/2010 10:48:14 PM 	TWA_ONKYOINTEGRA 	DEBUG MODE: Receiver 1 Command Found in Queue(PWR00)
11/27/2010 10:48:14 PM 	TWA_ONKYOINTEGRA 	In ButtonPressEx for TWA_ONKYOINTEGRA Power Control, button pressed is Power Standby
11/27/2010 10:47:04 PM 	TWA_ONKYOINTEGRA 	DEBUG MODE: Receiver 1 Command (WR00) Not Processed
11/27/2010 10:47:04 PM 	TWA_ONKYOINTEGRA 	DEBUG MODE: Receiver 1 Recieved Command(WR0) Code(0)
11/27/2010 10:47:04 PM 	TWA_ONKYOINTEGRA 	DEBUG MODE: Receiver 1 Number of Commands Recieved(1)
11/27/2010 10:47:04 PM 	TWA_ONKYOINTEGRA 	DEBUG MODE: Receiver 1 RAW DATA !1WR00
Also, the receiver is connected directly to the serial port on the computer. There is no usb-serial converter nor remote serial connection.
Cheers,
Mark
Old November 28th, 2010, 06:50 PM
DomeAdept's Avatar
DomeAdept DomeAdept is offline
Seer Plus
Hi Tom,
As for Marks problem, just a pointer: When I experience loss of data on a com port it usually is either a flow control problem (especially Xon/Xoff is known for this kind of trouble) or a routine which scans com ports (to see if certain hardware is connected). Also a possibility is an (deleted) modemdriver which still has active hooks in the system (softmodems are notorious in this case).
As for my bug report: The plugin's polling routine works great when the receiver is powered on. But with my Onkyo powered off, the plugin increases cpu use up to 50% or higher. This is tested on a clean install (2.4.0.1 -> 2.4.0.72) and confirmed by disableing the plugin.
Alex
Old November 29th, 2010, 03:11 AM
Cheers,
Mark
Wow that is weird, It shows the data is being lost before it even reaches the plugin... Raw data section of the log is after the plugin just reads in whatever data is waiting on the com port and prints it before doing anything... I could add a work around for the power command that will fix your issue... however i wonder if its an issue with more then just the power command? Could you check?
Ill do some research on com port data lost but have you checked liked domeadapt says? "a routine which scans com ports" because it could be scaning the ports at the same time and robbing some of that data...
-Tom-
Old November 29th, 2010, 03:13 AM
Originally Posted by DomeAdept View Post
Hi Tom,
Alex
I never checked or tested this, ill take a look, i think it might be an issue with a thread not being shut down correctly...
I am pretty busy this week.. im going to work on this first part of thos next week, i hope to hear back from manxam about his issue before then
-Tom-
Old November 29th, 2010, 12:32 PM
Since this issue first showed in your alpha/test builds, this machine has been wiped and a full reinstall done due to an issue that I was having with Windows bsod'ing on me.
This box is dedicated to HS so only has HS, APC Powerchute (usb), and iTunes. There have never been modem drivers installed nor can I think of any software that would be polling a com port.
Homeseer was loaded from a backup that did have piper's onkyo plugin as well as my onkyo/serial script enabled at one point but both are disabled and I've deleted all of the HSPI and related items (to the best of my knowledge).
Thanks for your help again,
Mark
Old November 29th, 2010, 06:05 PM
DomeAdept's Avatar
Seer Plus
Mark,
The Powerchute software suite from APC definetly monitors the com ports. This because of old APC models with rs-232 connections.
I would de-install all APC stuff (I personally like apcupd better since you can network your ups data and it has a HS plugin based on Jon00's script) and test if the com port still misses raw data.
Alex
Old November 29th, 2010, 09:44 PM
Mark,
Alex
Thanks for helping out here Alex, you've taught me a few things.. Let me know how it works out Mark..
-Tom-
Old December 1st, 2010, 03:16 PM
Sorry Guys, I should have clarified that the UPS in brand new (1 week old) and that this issue existed prior to this.
Thanks again,
Mark
