Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Z-Wave Plug-in
HomeSeer Z-Wave Plug-in Discussions relating to the Z-Wave plug-in
Old February 6th, 2015, 07:58 PM
Alconnell's Avatar
Alconnell Alconnell is offline
optimization error
I am just getting back into home automation after a year's absence and have got some zwave devices with the aeon usb stick. I tried to optimize and got an error and now whenever I try any type of optimization I get this:
Error - A previous Optimization is still in process or ended in an error. Complete the optimization successfully or reset your Z-Wave interface before attempting this operation again.
I have no idea how to clear this out so I can optimize again. Can't find anything in the threads. Any takers?
Old February 6th, 2015, 09:06 PM
rprade's Avatar
rprade rprade is offline
Try going to Plug-ins>Z-Wave>Controller Management. Expand the primary interface by clicking on the orange triangle to the left. Then under actions choose "Restart this interface", then click "Start". This will restart your controller.
Randy Prade
Aurora, CO
Prades.net
"Do or do not, there is no try"
-Yoda
Old February 9th, 2015, 10:58 AM
Alconnell's Avatar
I've tried that many times and tried re-starting HS. Nothing seems to work.
Old February 9th, 2015, 11:28 AM
clay2young's Avatar
clay2young clay2young is offline
On a Z-Troller
I do not know about your Z-stick, I use a Z-Troller. But, I have had an Optimization (Scan, Import, etc) lockup like that and give that (or similar) error message.
I Disable the Z-Wave plugin for a minute or two. Then Enable it. Next I shut down HS3, rebooted PC and restarted HS3. No errors on restart and and I could reset the interface as rprade described and continue Zwave operations as normal.
Good Luck!
2017-04-01: Shuttle XH81V Mini PC, dual RS232. Processor:Intel Core i7-477O5 - 3.1 GHz, 5.0 GT/s, 8MB. RAM: 16GB DDR3-1600MHz. Hard Drives:Two 240GB Internal Solid state disks (SSD). External 1T USB 3 drive. Dedicated for HomeSeer. (backup for other apps)
OS:Windows 10 Pro, HS3 3.0.0.315 with UACPass. Currently mostly Z-Wave Devices (137 nodes) 90%+ LED, Plugin 3.0.1.25, Z-NET 1.0.13. HSTouch .68, RFXCOM with 5 Sensors, MyQ plug-in, BlueIris, Pushover, Restart, Edge Browser.
Old February 9th, 2015, 11:30 AM
sparkman's Avatar
sparkman sparkman is offline
Which version of HS are you running? If HS2, you should be on 2.5.0.81 and if on HS3, I would recommend .152 with .189 of the z-wave plugin.
Cheers
Al
Rupp's Avatar
Rupp Rupp is offline
What version of HS3 are you running? What version of the Z-Wave plugin are you running?
-Rupp
Old February 10th, 2015, 08:15 AM
Alconnell's Avatar
You guys are good!
Just as I remember it - lots of help available. So I am on HS2 vs. 2.5.0.52....that is the latest version available to me in the updater. Zwave Plugin????? I don't see that, I am running the AEON stick version 2. It installs fine with the existing drivers. Boy do I feel like a newbie again!
Old February 11th, 2015, 10:22 PM
sparkman's Avatar
You can get 2.5.0.81 here: https://homeseer.com/older-downloads.html Also, If you are starting from scratch, I would suggest using HS3 as there really isn't a good migration path from 2 to 3, so if you go to 3 later on, you'll be manually redoing a bunch of stuff.
Cheers
Al
Old February 12th, 2015, 10:10 PM
Alconnell's Avatar
Thanks for the advice Al! I haven't got too far into my system rebuilding and I'll definitely give HS3 a lookover.
Z-Wave Optimization Help cd-card-biz HomeSeer Z-Wave Plug-in 6 March 12th, 2013 08:09 PM
Optimization error on Ztroller(s) Stuart Z-Troller™ 3 November 23rd, 2011 10:37 PM
How to reset after optimization error mikea Lighting & Primary Technology Discussion 2 April 5th, 2011 06:35 PM
Z-Wave Optimization Error Richel Z-Troller™ 4 February 24th, 2011 12:42 PM
Schlage Door Lock Optimization Error jasdev HomeSeer Z-Wave Plug-in 2 February 11th, 2011 12:14 AM
