Linux installation issue
    I've just installed the HS3 linux version to test, and have gone through a few different versions and get the same weird results.
    I am linux literate Ubuntu 14.04 LTS is the version, update/upgraded to today.
    Installed in /usr/local/HomeSeer as the tar zxvf command puts the files.
    Due to an error in speak.sh (pico2wave) I did have to 'sudo apt-get install pulseaudio'. There were a couple other packages I had to add per the linux install instructions.
    Started with the ./go script, manually, with and without sudo.
    The only differences between sudo and not seem to be the ability to start up the web server and having a home directory error, or not starting the web server and the home directory error goes away.
    Version 177 and 205 have the same results. I've done a clean install (rm -rf the HomeSeer directory) and untar'd to see if anything changed to no avail.
    On the homeseer web page, all of the "view" menu pages are accessible, and just the Tools/Setup/General page.
    Under Tools/Setup, if I change to any other tab but the General tab, it's blank.
    If I go to Plugins/Manage, the initial page comes up, but when I try to update the plugins it just sits at "wait" forever.
    Buttons don't seem to link anywhere either when I press them.
    Has anyone run across this weirdness, or have any thoughts where to start looking?
    As another question, is there a way to migrate an existing HS3PRO windows config file over to linux, so I don't have to manually create all the events?
    Some things you have to do on the install:
    Instead of what's listed in the install doc for the mono stuff, do this:
    sudo apt-get install mono-complete
    Ignore flite
    You will also need for the new sound stuff:
    sudo apt-get install libttspico-utils
    There's a new twist in pulseaudio...
    Users need to be in the pulse-access group.
    I edited the /etc/init/pulseaudio.conf per the following:
    # uncomment the 'start on' to start pulseaudio in system mode
    So change
    #start on runlevel [2345]
    to
    Now it starts as a system daemon, and will play for everyone as long as they are in the pulse-access group.
    The comments in that file describe some other issues:
    # System mode is not the recommended way to run PulseAudio as it has some
    # limitations (such as no shared memory access) and could potentially allow
    # users to disconnect or redirect each others' audio streams. The
    But since this is a dedicated server, this shouldn't pose any issues.
      Also here went to using Ubuntu LTS stripped down to the nub and removed everything that has anything to do with the internet. You can also utilize LUbuntu but it was too lite for me.
      A DIY posting here on your build would help other Homeseer 3 users doing this in Ubuntu.
      How to install Homeseer 3 on Ubuntu 14.04 LTS 64 bit.
      You can be the primary author and I will help if you want.
        You need to add this to the install doc mono part:
        sudo apt-get install mono-vbnc
        sudo apt-get install sqlite3
        Ignore flite
        So change
        to
