Weekend of Sep 9-10
Post a new beta with the rewrite of the maps section. No more ini file.
Lots of changes documented in a pdf file.
After the beta release
Start on the next feature which is to start putting the rain totals in inches and to add the devices that have been asked for dealing with rain. I plan on adding two new database columns to store the hourly and total rain each time the conditions schedule runs.
The following is a combination of several peoples past posts
Forecast Info:
Today's forecast for rain in inches
Tomorrow's forecast for rain in inches
Day 2 through Day 9 Forecast rain in inches
Historical Data
Rain Totals for a user specified number of days in the past. Up to 7. If you need more you can query it from the database. (See below)
1, 2, 3, 4, 5, 6 and 7 day's ago. These will be daily totals. Not cumulative.
1, 2, 3, 4, 5, 6 and 7 day's ago. These will be cumulative.
There is already a function in weatherXML that allows you to send a database query and the results will be returned as an array that you can loop over in a script if you need different data. This will allow you to target any of the data being stored in the weatherXML database.
Forecast Info:
Historical Data
