I think I got a corrupted install. It thinks it installed correctly. The install was before a windows update rebooted the machine. I know I have greater than .Net 4.5 installed. The OS is Win10.
Log files below:
Dec-17 1:29:54 PM Info Plugin Ecobee with instance: has disconnected
Dec-17 1:29:53 PM Plug-In Finished initializing plug-in Ecobee
Dec-17 1:29:52 PM Ecobee INFO Ecobee version 3.0.0.13
Dec-17 1:29:52 PM Info Plugin Ecobee has connected. IP:127.0.0.1:53986
Dec-17 1:29:52 PM Plug-In Interface Ecobee is running as a trial, 29 days remaining.
Dec-17 1:29:41 PM Updater Install/Update of package Ecobee was successful.
Dec-17 1:29:41 PM Updater Copying file: C:\Program Files\HomeSeer HS3\Config\\Ecobee.ini
Dec-17 1:29:41 PM Updater Extraction Complete.
Dec-17 1:29:41 PM Updater Extracting files from zip file: images.zip
Dec-17 1:29:41 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\Ecobee\System.Time.dll
Dec-17 1:29:41 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\Ecobee\Ecobee.Net.dll
Dec-17 1:29:41 PM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\Ecobee\Newtonsoft.Json.dll
Dec-17 1:29:41 PM Updater Making dir: C:\Program Files\HomeSeer HS3\bin\Ecobee\
Dec-17 1:29:41 PM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_Ecobee.exe.config
Dec-17 1:29:40 PM Updater Installing package Ecobee
Dec-17 1:29:40 PM Updater Update HSPI_Ecobee.exe downloaded successfully
Dec-17 1:29:39 PM Updater Downloading update: Ecobee
Dec-17 1:29:39 PM Updater Starting download of updates
Error message:
Dec-17 3:00:05 PM Info Plugin Ecobee with instance: has disconnected
Dec-17 3:00:04 PM Plug-In Finished initializing plug-in Ecobee
Dec-17 3:00:04 PM Ecobee INFO Ecobee version 3.0.0.13
Dec-17 3:00:04 PM Info Plugin Ecobee has connected. IP:127.0.0.1:58580
Dec-17 3:00:04 PM Plug-In Interface Ecobee is running as a trial, 29 days remaining.
Log files below:
Error message:
