This thread will be to list the changes for the beta versions of weatherXML.
New beta versions will be available in the HS updater in the Beta section near the bottom of the list.
3.0.0.64
This is a huge change. Please make a backup of all your files before testing this version. The tracking of weatherXML HS devices will be tracked by the device address rather than trying to keep them straight in an ini file. You may have to delete and re-add some devices.
* Added a setting to control how many of the backup files to keep. Oldest ones are deleted as new ones are saved.
* Fixed a bug with the download backup that was saving the wrong file for the Alerts backup.
* The map rotation device option is now hidden until at least one map has been setup.
* Added setting to allow selecting which locations will create Global Variables.
* Now tracks the device refIDs based on actual devices instead of storing the refID in an ini file.
* Added the ability to set an image width or height for display on the weatherXML users Map page.
* Added the ability to resize a downloaded Map image
* Fixed the Event device references to work correctly
* Fixed the PHLocation dropdowns to use the Location 1 first setting.
3.0.0.64
