So my Zee is out of disc space. I can't even make a backup. I only have two plugins - BLDSC and Zwave. It is possible that the BLDSC-Activity.log is too big, but I'm not sure where to find it in the Zee's file system. Or maybe it's another problem.
What's the best way to troubleshoot this?
Filesystem Size Used Avail Use% Mounted on rootfs 7.6G 7.5G 0 100% / /dev/root 7.6G 7.5G 0 100% / devtmpfs 482M 0 482M 0% /dev tmpfs 98M 238k 97M 1% /run tmpfs 5.3M 0 5.3M 0% /run/lock tmpfs 195M 13k 195M 1% /run/shm /dev/mmcblk0p5 62M 20M 43M 32% /boot tmpfs 487M 291k 486M 1% /tmp tmpfs 487M 127k 486M 1% /var/log tmpfs 487M 0 487M 0% /var/tmp
