My version of the datagrid control is 6/23/1998 on both my xp and w2k computers so it is likely you have the same one. I can give you the source if you are setup for VB and have any interest.
I looked at my xml file and a typical ocelot variable looks like the following with interface being 'applied digital ocelot'. The plugin does look for this to identify its devices, but it also looked for it with v1.7.0. It is the same name used by the HST plugin so it would easy for people to switch back and forth.
I can put some debug code in to see what has changed. Let me know.
<z:row record_type='1' can_dim='False' dc='56' dev_type_string='Interface Variable' hc='[' interface='applied digital ocelot'
iomisc='' iotype='3' location='ocelot' misc='0' name='channel - count (ir 253 out)' ref='33912' sldim='0' status='17'
status_support='False' ui_action='' buttons='' values='' zwave_nodeid='0' zwave_nodetype='0' zwave_pollrate='0'
CS_Status='0' IS_Label='' IS_Ircommand='' IS_Value='0' IS_Image='' IS_Row='' IS_Column='' delete='False' dtmf=''
eprom_address='' ev_abs_time='0' ev_app_path='' ev_date='' ev_days='0' ev_dimpercent='0' dim_to='False' ev_func='0'
ev_hc='' ev_mail_message='' ev_mail_subj='' ev_mail_to='' ev_offset='' ev_offset_before='False' ev_time='' ev_trig_dc=''
ev_trig_func='0' ev_trig_hc='' ev_wav_path='' events='' group='' handled='0' ir='' irmatch='0' mail_attach_path=''
evmisc='0' misc_actions='' evmisc2='0' evname='' phone_actions='' phone_event='0' phone_line='0' pi_trig_name=''
pi_trigger='' popfrom='' rec_mins='0' rec_secs='0' relay='' scripts='' sec_action='' sec_trigger='' security_offset='0'
speak_after_script='' speak_before_script='' speak_device='0' speech='' vcmd='' pi_actions='' cd_condition='0'
cd_ctype='0' cd_dev_ref='0' cd_time='' cd_orindex='0' cd_plugin='' dev_devid='0' dev_dim_percent='0' dev_dimto='0'
dev_eprom_address='0' dev_func='0' dev_new_string='' dev_secs_delay='0' setpoint_action='0' tv_daytime='0' tv_daytimerdate='1899-12-30T00:00:00'
tv_moddev='' tv_modhouse='' tv_nolimit='False' tv_passdev1='' tv_passdev2='' tv_passdev3='' tv_passdev4='' tv_passhouse=''
tv_status='0' tv_timetype='0' tv_totaltime='0' tv_useddaytime='0' tv_usedtime='0' tv_username='' retrigger_delay='0'
graphics=''/>
graphics=''/>
