I believe we put up a new version in the Beta section last week, 3.0.0.46, give that a try I think there was some COM port fixes.
DSC plugin release version 2.0.0.14
Originally posted by abuck View PostI was wondering if you guys are working on a plugin wich would be compatible with the new DSC NEO panels ?
Originally posted by mwijas View PostI just upgraded to version 3.0.0.45 and it is still not working. Issue is described above - can someone PLEASE provide some troubleshooting steps. All I am looking for is basic troubleshooting steps when DSC plugin is not working. Thanks!
I restarted HS3 and it still didn't work. I completely shut off the Hometroller and rebooted and everything works ok now. I guess the com port in the Hometroller needed a power on reset.
- Robert
I'm seeing this in 3.0.0.46 as well. I have 32 zones that have not updated their statuses in over 24 hours. One of my events checks if a motion sensor haven't detected motion in 30 mins, turn off the lights. When of course, as soon as you manually turn on the lights, it turns it right off cause the motion sensor hasn't detected motion in 24 hours.
If I enable status logging, I see messages from the panel when zones are changing, but not on the device status page.
The LCD Update usually updates every minute with the time, but doesn't until I hit reset status.
Originally posted by RJS View PostHave you shut your Hometroller completely off and restarted it?
- Robert
Code:Jan-27 11:57:40 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time JAN 27/15 11:57p2B Jan-27 11:56:56 PM DSC Security Panel Response Processing response: Zone Restored->6100062D Jan-27 11:56:55 PM Z-Wave Device: Security Living Everspring Motion Sensor Set to Off/Closed/No Motion Jan-27 11:56:49 PM Z-Wave Device: Security Living Front Door Lock Set to Locked Jan-27 11:56:49 PM Z-Wave Device: Security Living Front Door AC Notification Set to NOTIFICATION for type Access Control Notification, Event: Manual Lock Operation Jan-27 11:56:49 PM DSC Security Panel Response Processing response: Zone Opened->60900635 Jan-27 11:56:46 PM DSC Security Panel Response Processing response: LED Status->90311FE Jan-27 11:56:46 PM DSC Security Panel Response Processing response: Zone Restored->6100062D Jan-27 11:56:46 PM DSC Security Panel Response Processing response: Partition Force Armed->6531CF Jan-27 11:56:46 PM DSC Security Panel Response Processing response: Beep Status->90400633 Jan-27 11:56:46 PM DSC Security Panel Response Processing response: Zone Restored->61000128 Jan-27 11:56:44 PM Event Event Trigger "Security Auto Lock Doors" Jan-27 11:56:44 PM Z-Wave Device: Security Living Front Door Lock Set to Unlocked Jan-27 11:56:44 PM Z-Wave Device: Security Living Front Door AC Notification Set to NOTIFICATION for type Access Control Notification, Event: Manual Unlock Operation Jan-27 11:56:44 PM DSC Security Panel Response Processing response: LED Status->90310FD Jan-27 11:56:44 PM DSC Security Panel Response Processing response: Partition Not Ready->6511CD Jan-27 11:56:44 PM DSC Security Panel Response Processing response: Beep Status->90400633 Jan-27 11:56:44 PM DSC Security Panel Response Processing response: Zone Opened->60900130 Jan-27 11:56:40 PM DSC Security Panel Response Processing response: Zone Opened->60900635 Jan-27 11:56:40 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time JAN 27/15 11:56p2A
Originally posted by Sireone View PostThis my DSC alarm status as of 10 mins ago after a reboot of the Homeseer PC. Still no status update of devices. If I 'Enable Status Logging', I immediately start seeing data from the panel in the log, so I know the communication is working. The devices are just not refreshing. And unfortunately my events are based on the device status, so none of them work! The only way I get this to work is if I delete ALL my DSC devices and re-add them by saving the DSC zone settings. This causes new Ref IDs and screw up my scripts.
Deleting the DSC devices would be a Hail Mary. However, if you use the default device names, why would it screw up your scripts? All your HSTouch devices will be different for sure and I think your events would have to be fixed as well.
I understand your dilemma. If you delete then re-add, will you have to go through this again once the bugs in the plugin are fixed? I have a feeling that it will be several weeks for the bugs are fixed.
I wish I could offer some concrete suggestions.
- Robert
Short of a Hail Mary, try this -
- Roll back to 3.0.0.45
- Shut off the Hometroller
- Shut off the alarm panel and disconnect the battery
- Wait a couple of minutes
- Install the battery
- Turn on the alarm panel
- Turn on the Hometroller
If the comms are not 100% correct, this might force both the alarm panel and HS3 to reset.
- Robert
