Bob, having some issues with the plugin and/or the ISY. I am using v 1.0.3 of your plugin and the latest stable 2.8.16 version of the ISY firmware. Basically if I try to turn a device on/off or to a certain % dim it doesn't work. If I toggle status or use a scene to control, it works. Everything seems to work fine when HS first boots, the issue happens after some time. If I reboot HS, the issue is fixed temporarily. If, instead, I reboot the ISY via unplug, replug of the PLM, that does not fix the issue so I believe it is somewhere within the plugin or HS.
Attached is my log set to ALL. I had a light in my kitchen that was on. I tried turning off, then setting dim to 0% with no luck. I then turned off with a toggle and on with a scene. Hope the attached is useful in debuging.
Matt
Matt
