Go Back   HomeSeer Message Board > RFID Plug-ins > RFID Discussion
Old September 11th, 2012, 12:17 PM
mark_anderson_us mark_anderson_us is offline
A new take on RFID
Hi All
Just got back from CEDIA and saw an impressive demo of RFID on the Crestrn booth using NFC. Of course, as with everything Crestron, its called something else: AirConnect.
rather than putting expensive readers everywhere that have to be physically connected to some central system, Creston's solution uses $1 self-adhesive NFC tags that you can put anywhere (e.g. on the back of a light switch cover). When you swipe your NFC enabled phone over the sticker, it uses the phones Wifi to relay the information back to the central server and do wahtever is supposed to be done (e.g unlock door, turn on lights, etc.).
Would be great to have NFC support in HSTouch, and configure it so that reading a sticker would send back a sticker ID and user ID and then run a script that would do something location and user specific. For example, if I come home, unlock door, turn on lights, play my favorite music. If my wife comes home, unlock door, turn on lights, remind her to empty dishwasher (just joking).
Obviously, this won't work for things like opening the garage when pulling into drive, but would be great for most other things
Dell Zino HD - HSPRo 2.x
HSTouch - iPhone 3GS, 4S, iPad2 and iPad 3, 3xKindle Fire (Wall mounted)
2 x Brultech ECM1240 with UltraECM
Cooper Aspire Z-Wave Switches
WGL800 w ACRF2 and 3xDS10a (Sump Level/Activity sensing)
HM ST812-2 Flood Sensor
HSM100 - Motion Detector with Light and Temperature
2GIG Thermostat
BLDSC - Alarm Plug-in
UltraLog (SQL2008)
Jon00 Plugins
Host XR3 BT and Jon00 BT Proximity
Global Cache IP2IR
Foscam FI8918W
Old September 11th, 2012, 12:51 PM
pbibm's Avatar
pbibm pbibm is offline
Interesting. My Samsung Galaxy SII Skyrocket came with NFC and the ICS release of android lets it be used at OS level between 2 phones when you touch them. It will be interesting to see this play out for HA when the tags are that cheap.
