I have ELV MAX! radiator thermostats in my house controlled with HS2.
Sometimes the connection of a thermostat failes.
Homeseer looks at the devicevalue of the thermostats every 5 minutes.
The device value is eg. 170000 : It contains the setpoint (17 celsius) and the valve% (=%).
I created a device value change triggerevent for the thermostat - it runs every time if the device value of the thermostat changes.
After the connection of the thermostat failed the device value change triggerevent doesn’t run anymore because the devicevalue of the thermostat does’t change anymore and remains constant.
Now I want to create another event wich triggers depending on the time difference between the currently time and the last time of the device value change triggerevent of the thermostat.
( For an example: The corrently time is 10.00 / the last time of the device value change triggerevent was 07.00 - the time difference between is 180 minutes ).
This another event I want to use for a restart of my radiator thermostat to reconnect it to my
HS 2 system every time the time difference has a specific value.
My question is : how to do this ?
Regards, Fischi
Regards, Fischi
