Go Back   HomeSeer Message Board > RFID Plug-ins > RFID Discussion
Old July 11th, 2014, 02:09 PM
Automated Automated is offline
Just put a coax pigtail on it, and then run some RG-6 to your attic. There you can use something like a cheap Radio Shack or other branded discone broadband antenna, make your own ground plane, or use something like one of the older TV antennas (I do this and get lots of signal just fine). Some purists will say to use 50 ohm cable instead of 75 ohm cable, but here is a little hint...it won't make any difference in this particular application, and receiving only, so just use the cheap quad shielded RG-6 as it is readily available (same like what is used for your TV/Cable company run).
Something like this: http://www.amazon.com/coaxial-cable-...dp/B00CKG6T9I/
Cut the gold end of, and strip the insulation back about a quarter of an inch. Solder the inner conductor where the wire comes out of your receiver (remove the wire). Solder the outer shield conductor to the ground plane of the board (negative).
Old February 3rd, 2016, 11:29 AM
Pete's Avatar
Pete Pete is offline
Pete, you need to tap the output pin on the pic, and feed that into a max3232 ttl to serial chip. You can just leave their pumping transistor there. Then feed 5v past their serial port connected regulator where they try to pull power off the serial line. Use this also to feed power to the serial converter chip, with both then getting a common ground. Hookup power and a serial port on the rs232 side of the converter chip and you are in business.
I am writing this from memory on my phone, and I know you have the knowledge to figure it out from that, but let me know if you need a picture, and I can go look at mine.
Bringing this back as I have been playing a bit with it and unmodified it has been working fine for me.
I have a bunch of these that output via USB or Serial.
Where are the connection points on the RFID receiver that I have to connect to?
I am using the 12VDC RFID devices in the automobiles with the small antennas on them. I have moved the device such that the antenna has a better view.
RF40315T-x Active RFID 40 Meters Transmitting Module
Main RFID receiver is in the attic with the ground plane up (might reverse it). I have a bunch of these and today just use 2 of them. One is powered and the other one is not. Both work fine. I will take a better picture of a test one to modify.
Testing right now it works fine from the entrance of my subdivision getting a text page tickle when it is activated. It is about 4 minutes or so before I get to my driveway. Ideally for this test will utilize granular GPS coordinates maybe using the carpc as the ack box to the RFID stuff.
This is a picture depicting the distance that is working for me today. On the right is the entrance to the subdivision and the left is where the house is.
I now have this working better than when I did this picture.
Just curious if you could provide a schematic and pictures of your modifications?
Here just watching the serial output of the RFTags as they come in to view never see any issues with the data.
Nowadays it would probably be better to make it a little RPi2 project using a serial RF receiver/transmitter (miles range) and GPS device. You could build one of these for less than $100 USD.
Here is a pair of Zigbee devices which work at 1000 meters that could work in this endeavour. Just connect this gizmo to an RPi2 / GPS. This is not RFID but would work even better.
1 - Input Voltage : DC 5V~12V
2 - Working Temperature : -40C - +85C
3 - UART Rate : 38400bps(Default), can select 2400,4800,9600, 19200, 38400, 57600, 115200
4 - Frenquency : 2405MHz(Default),can select 2405~2480,Step 5MHz,Total of 16 channels
5 - Transmiter Protocol : Zigbee 2007/PRO
6 - Two point type for Zigbee network : Router(Default),Coordinator
7 - Transmiter Distance : Open environment Maximum 1000M
8 - Send Current : 150MA (Max),Receive Current: 45MA (Max),Average current 60MA(Typical)
9 - Receive Sensitive: -96dBm
10 - Main Chip: CC2530F256 + CC2591, peal Zigbee 2007 protocl
11 - Interface :RS232(PIN2 TX;PIN3 RX;PIN5 GND)
12 - Size:66*55*27(Excluding antennas, connectors, mounting bracket)
Hardware | Haswell Intel iSeries 3 - 16Gb | Pine64 - 2Gb computers | Openpeak Intel Atom tabletop touchscreens
HS3 Pro & Lite
Edition Beta | HS3 Wintel Touch | Ubuntu 16.04 64 bit | Oracle Windows Virtual Box ==> for Wintel only SAPI and HS3 plugins
HS3 Plugins - a bunch
Light switches - X10,UPB, ZWave and Zigbee
Speech - Microsoft SAPI - Neospeech - Amazon Echo
Security - Leviton HAI Omni Pro 2
Weather - Davis Vantage Vue - MeteoStick
Firewall - PFSense
CCTV - Zoneminder
Audio - Russound - AB8SS
Old February 2nd, 2018, 06:25 PM
rmuziani rmuziani is offline
What Frequency should I buy 315 Mhz or 433?
Old February 2nd, 2018, 07:39 PM
Michael McSharry's Avatar
Michael McSharry Michael McSharry is offline
Probably 433 as it has slightly better range. If you were in Europe 315 would not be allowed, but both are within the allocated USA spectrum. Just make certain you have matching transmitter and receiver. I have two versions. One that includes signal strength. In both cases, however, I never really found them to be that useful. Especially today with other options for geofencing type applications.
Old February 3rd, 2018, 07:25 AM
Pete's Avatar
Yeah here I permanently installed the transmitter in the headliner above the dome light on all of the vehicles and connected it to the automobile battery.
Close by the car dome light transmitter also have the built in Homelink. Here extended the antenna on the GDO where the range is much better from the car.
I test it using the garage door hard switches connected to the alarm panel with a remote connected to my mobile phone.
Mostly too keep the cell phones off when not used. That said the newer automobiles have 3 G radios any how that are always on when the car is running. I did want something that I could track independent of the cell phones.
I have only replaced one TX in over 10 years of use now. The automobile tags provide status to Homeseer and I use them for TTS announcements relating to what personal automobile is approaching the garage or leaving the garage but not for the security system on or off type of stuff. That and have a hard switch via these boxes to turn on lightning that is off at night. Garage, hallway from garage type of stuff. I also redid lighting in garage using LED daylight look and have disabled the PIR in the garage and using hard switches for sensors.
I had two RX boxes and have reduced it to one now and it works fine in the attic with one antenna.
Ideally would like to integrate it with alarm panel (as Homeseer monitors alarm panel) and the company does make an RX board with solenoids which can be connected to the alarm panel.
RF2315R Active RFID Dual Receivers Module with RSSI USB Version mminehan xAP Discussions 4 October 6th, 2011 05:59 AM
DS10 Active RFID Uncle Michael Wireless Receiver & Transceiver Discussion 0 May 16th, 2009 11:29 AM
Passive versus active RFID tdlewis77 RFID Discussion 4 February 2nd, 2007 09:47 PM
Pango Wi-Fi Active RFID Chris Couture Plug-In Development 5 April 1st, 2006 12:32 PM
RFID Readers with Active Tags for HomeSeer pmonahan General Home Automation Hardware Discussion 112 April 12th, 2005 03:51 PM
