Constantly reconnecting
    I just upgraded to version .142, and found the HS log full of reconnect messages.
    aug-26 14:02:38	 	Arduino Plugin	Updating Values on Board No: 1
    aug-26 14:02:37	 	Arduino Plugin	Updating pins on Board No: 1
    aug-26 14:02:37	 	Arduino Plugin	Connected to Board No:1 at ip address 192.168.0.91 Port No:8900
    aug-26 14:02:37	 	Arduino Plugin	Board 1 Version 1.0.0.142 and Plugin Version 1.0.0.142 are compatible.
    aug-26 14:02:37	 	Arduino Plugin	Connecting Board No:1 at ip address 192.168.0.91 Port No:8900
    aug-26 14:01:13	 	Arduino Plugin	Updating Values on Board No: 1
    aug-26 14:01:12	 	Arduino Plugin	Updating pins on Board No: 1
    aug-26 14:01:12	 	Arduino Plugin	Connected to Board No:1 at ip address 192.168.0.91 Port No:8900
    aug-26 14:01:12	 	Arduino Plugin	Board 1 Version 1.0.0.142 and Plugin Version 1.0.0.142 are compatible.
    aug-26 14:01:12	 	Arduino Plugin	Connecting Board No:1 at ip address 192.168.0.91 Port No:8900
    aug-26 13:59:48	 	Arduino Plugin	Updating Values on Board No: 1
    aug-26 13:59:47	 	Arduino Plugin	Updating pins on Board No: 1
    aug-26 13:59:47	 	Arduino Plugin	Connected to Board No:1 at ip address 192.168.0.91 Port No:8900
    aug-26 13:59:47	 	Arduino Plugin	Board 1 Version 1.0.0.142 and Plugin Version 1.0.0.142 are compatible.
    aug-26 13:59:47	 	Arduino Plugin	Connecting Board No:1 at ip address 192.168.0.91 Port No:8900
    aug-26 13:58:23	 	Arduino Plugin	Updating Values on Board No: 1
    aug-26 13:58:22	 	Arduino Plugin	Updating pins on Board No: 1
    aug-26 13:58:22	 	Arduino Plugin	Connected to Board No:1 at ip address 192.168.0.91 Port No:8900
    aug-26 13:58:21	 	Arduino Plugin	Board 1 Version 1.0.0.142 and Plugin Version 1.0.0.142 are compatible.
    aug-26 13:58:21	 	Arduino Plugin	Connecting Board No:1 at ip address 192.168.0.91 Port No:8900
    It's like it's reconnecting at least every other minute. It didn't do that before...
    (Arduino Mega 2560).
    I've been running 142 for a while without issue.
    What version did you upgrade from?
      I've also been running .142 for sometime without issues. I did however have issues early on when I started playing with arduino and it was all due to power issues I had to the board - as in not supplying enough current. Has your project changed? Did you expand your scope? Just a thought...
      Robert
        Errr.... I think it was .138. This is an Arduino with an ethernet shield.
        According to PRTG (which I've set up to ping it constantly) it has no problems with the ethernet connection.
        I also have a NodeMCU connected with the same version, and the NodeMCU has no issues.
          Robert
          No, I haven't changed anything in the project, but I'll check the power supply.
            Okay, I replaced the 1A adaptor with an 2A. Still seems to reconnect every other minute.
              I've seen this reconnect behavior when I had 2 boards with the same credentials (IP,mac, BoardAdd). Due to the way I manage sketches for multiple boards, it happens to me every once in a while. I've seen it enough that I know what is wrong. Fix the credentials and it goes away.
              Don't know if this might be a possibility for you. Just a thought.
                Originally posted by logbuilder View Post
                I've seen this reconnect behavior when I had 2 boards with the same credentials (IP,mac, BoardAdd). [...] Fix the credentials and it goes away.
                Thanks for the input!
                However, this happened before I added the NodeMCU, so there was just one board connected...
                (And I've made sure the MAC-addresses are different, the IPs are of course different).
                  I have the same issue , and i think i find a good way to reproduce it
                  1) disconnect power to any board for a few moment
                  (i would say anything higher than 2 minute to be sure)
                  2) plug power back to the board and let the autoreconnect magic happen
                  (sometimes i have to press reset on the ethernet shield or else the led on the shield never start and i have no network connectivity , but thats an other problem)
                  3) now every 2 minutes you got an automatic reconnection to the board
                  the only way to stop this reconnect loop is to shutdown Arduino plugin within homeseer and start it back a few seconds later (or restart homeseer completely)
