Thanks. Will try after work. Can you give me an example of the xxxx after DeviceType? Is it based on Insteon device (dimmer, KeyPadLinc, etc.)? If yes, could you give an example for a SwitchLinc dimmer?
Lost all Insteon devices
The devicetype is a four digit numerical code. I have a new idea for getting this all back together.
1. save off the good homeseer database with your insteon hs devices
2. register all your insteon devices in the plugin to rebuild the insteon.ini
3. replace the current homeseer database with the 'good' homeseer and restart hs
this may reconnect the insteon devices with the hs devices so your triggers and events aren't broken.Mark
HS3 Pro 4.2.19.5
Originally posted by independentpete View PostWhen you say to register the devices, you mean to add or tap-add them all into the plugin, right?Mark
HS3 Pro 4.2.19.5
Success!! So far, kind of... I had open the HSD file that contained all my HS devices. I re-added one dimmer switch to the plugin. It connected and assigned the same old HS Device ID, so events are still good. I restarted HS. That device remained in HS, in the plugin, and in the Insteon.ini file.
BUT... The rest of my devices, which were in HS but not in the plugin, we all wiped out from HS again. :-( So, I guess the procedure is to keep adding the rest of them this way before restarting HS.
Thanks again Mark!! I'll update on progress here again later. When I'm all done, I'll update to the latest plugin version to avoid losing the Insteon.ini in the future.
Hey Mark,
I have seen similar behavior since my most recent upgrade to Insteon plug-in 3.0.6.0. I haven't lost the Insteon devices on the manage device page, but the references to the devices have changed. My events for Insteon devices stopped working, when I view the events I see "device with ref=xxx not in the system." This has happened twice, and I need to rebuild the events.
Any idea what is causing the device references to change?
John
John
I would recommend rolling back to an insteon.ini and homeseer database from the same day.
upgrading the plugin should not change dev refs.Mark
HS3 Pro 4.2.19.5
Originally posted by blueline View PostI haven't made any Insteon device changes. It happened twice with this version of the plug-in but didn't occur immediately following the upgrade. I would also add that it seems to have occurred both times after a reboot.Mark
HS3 Pro 4.2.19.5
Hi Mark,
I recreated all of my events that have Insteon devices in them. They all were working, but now I see that the events are "corrupt" again showing the missing device references. There is nothing in the Homeseer log that shows anything other than:
Event Sunset Triggered Welcome Home, Action of Control a Device could not be carried out because its configuration is not complete.
jc
jcMark
HS3 Pro 4.2.19.5
Originally posted by blueline View PostWhen I look at the event definition for the event that i included in my screenshot, the device reference ids did change. Something is causing the plugin to change the ids. Which logs would be helpful to troubleshoot?Mark
HS3 Pro 4.2.19.5
Hi Mark,
The plug-in is creating devices. Here's the log.
jc
Insteon Plug-in Error Log Generated 12/20/2016 9:10:05 AM
-----------*Error Message*----------------
Error: Error in SetHSDeviceStatusAndValue: Object reference not set to an instance of an object. -- Details System.NullReferenceException: Object reference not set to an instance of an object.
at HSPI_Insteon.hspiAPI.HSAPI.GetDeviceAddress(Int32 ref)
at Insteon.Support.Core.InsteonModule.SetHSDeviceStatusAndValue (Int32 ref, Int32 Level, Boolean IsAPollUpdate) -- 12/20/2016 9:10:05 AM
--------*Initialization Log*--------------
12/19/2016 6:55:59 AM - Host System: () 3.0.0.297
12/19/2016 6:55:59 AM - Plugin HSPI_Insteon.exe version: 3.0.6.0
12/19/2016 6:55:59 AM - Insteon Support library (Insteon.dll) version: 1.0.6.0
12/19/2016 6:55:59 AM - RegisterCallback Completed
12/19/2016 6:55:59 AM - Enter InitIO
12/19/2016 6:55:59 AM - Enter InitPlugin
12/19/2016 6:55:59 AM - Global initialization of plug-in required, starting up.
12/19/2016 6:55:59 AM - In ProcessRawReceiveThread
12/19/2016 6:55:59 AM - Initializing Insteon hardware interface...
12/19/2016 6:55:59 AM - Initializing Interface...
12/19/2016 6:55:59 AM - In PLMBuffer_ProcessBufferThread
12/19/2016 6:56:01 AM - Sending command 02 60 to Interface, (Expecting 6 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/19/2016 6:56:01 AM - ..Got Interface Response 02 60 39 55 8F 03 15 9E 06
12/19/2016 6:56:02 AM - ..Got Interface Response 02 60 39 55 8F 03 15 9E 06
12/19/2016 6:56:02 AM - RF PLM contacted on COM6 with an Insteon address of 39.55.8F and firmware version 9E
12/19/2016 6:56:02 AM - ResourceManager::RequestExclusive for Resource 1
12/19/2016 6:56:02 AM - ResourceManager::RequestExclusive acquired for Resource 1
12/19/2016 6:56:02 AM - Sending command 02 6B 48 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False
12/19/2016 6:56:02 AM - ..Got RF PLM Response 02 6B 48 06
12/19/2016 6:56:02 AM - ResourceManager::ReleaseExclusive for Resource 1
12/19/2016 6:56:02 AM - Insteon hardware interface initialized.
12/19/2016 6:56:02 AM - I/O (Insteon Protocol) Interface Initializing...
12/19/2016 6:56:02 AM - In TransmitMessageThread
12/19/2016 6:56:02 AM - Scheduled polling enabled.
12/19/2016 6:56:02 AM - In CreateDevices
12/19/2016 6:56:02 AM - Scheduled polling temporarily stopped.
12/19/2016 6:56:02 AM - Reloading 2 Insteon group information tables...
12/19/2016 6:56:02 AM - Reloading 53 Insteon device information tables...
12/19/2016 6:56:11 AM - [HCM] Creating new HomeSeer device: Bottom Stairs (1F.6E.C2:1)
12/19/2016 6:56:12 AM - [HCM] Creating new HomeSeer device: Bottom Stairs (3E.01.AE:1)
12/19/2016 6:56:13 AM - [HCM] Creating new HomeSeer device: Closet Light (10.99.22:1)
12/19/2016 6:56:13 AM - [HCM] Creating new HomeSeer device: Top Stairs (10.9A.AA:1)
12/19/2016 6:56:13 AM - [HCM] Creating new HomeSeer device: Recessed Lights (Kelly Side) (07.39.D1:1)
12/19/2016 6:56:13 AM - [HCM] Creating new HomeSeer device: Chandelier (1B.C1.47:1)
12/19/2016 6:56:13 AM - [HCM] Creating new HomeSeer device: Hutch (14.7E.5C:1)
12/19/2016 6:56:13 AM - [HCM] Creating new HomeSeer device: Recessed Lights (0B.73.57:1)
12/19/2016 6:56:13 AM - [HCM] Creating new HomeSeer device: Recessed Lights (03.92.67:1)
12/19/2016 6:56:13 AM - [HCM] Creating new HomeSeer device: Outlet (12.A5.BA:1)
12/19/2016 6:56:13 AM - [HCM] Creating new HomeSeer device: Unknown (04.2D.6B:1)
12/19/2016 6:56:13 AM - [HCM] Creating new HomeSeer device: Bottom Stairs (03.8A.6D:1)
12/19/2016 6:56:14 AM - [HCM] Creating new HomeSeer device: Exterior Security Lights (04.2A.96:1)
12/19/2016 6:56:14 AM - [HCM] Creating new HomeSeer device: Ceiling Light (07.2D.65:1)
12/19/2016 6:56:14 AM - [HCM] Creating new HomeSeer device: Post Light (04.2E.2C:1)
12/19/2016 6:56:14 AM - [HCM] Creating new HomeSeer device: Xmas - Bathroom (07.A1.ED:1)
12/19/2016 6:56:14 AM - [HCM] Creating new HomeSeer device: Xmas - Candles (07.A2.05:1)
12/19/2016 6:56:14 AM - [HCM] Creating new HomeSeer device: Xmas - Family Room Left (14.7B.3C:1)
12/19/2016 6:56:14 AM - [HCM] Creating new HomeSeer device: Xmas - Family Room Right (20.B6.29:1)
12/19/2016 6:56:15 AM - [HCM] Creating new HomeSeer device: Xmas - Front Mudroom (14.7B.41:1)
12/19/2016 6:56:15 AM - [HCM] Creating new HomeSeer device: Xmas - Garage Left (18.EB.D7:1)
12/19/2016 6:56:15 AM - [HCM] Creating new HomeSeer device: Xmas - Garage Right (18.EC.C0:1)
12/19/2016 6:56:15 AM - [HCM] Creating new HomeSeer device: Xmas - Guest Bedroom (14.7D.49:1)
12/19/2016 6:56:15 AM - [HCM] Creating new HomeSeer device: Xmas - Tree Candle (18.EF.2D:1)
12/19/2016 6:56:16 AM - [HCM] Creating new HomeSeer device: Xmas - Tree (14.7B.25:1)
12/19/2016 6:56:16 AM - [HCM] Creating new HomeSeer device: Light (0B.E9.97:1)
12/19/2016 6:56:16 AM - [HCM] Creating new HomeSeer device: Rear Fan Light - Remote (03.8A.1E:1)
12/19/2016 6:56:16 AM - [HCM] Creating new HomeSeer device: Fan Light - Front Remote (03.92.E2:1)
12/19/2016 6:56:17 AM - [HCM] Creating new HomeSeer device: Fan Light (07.4C.4A:1)
12/19/2016 6:56:17 AM - [HCM] Creating new HomeSeer device: 6-Button - Button On/Load (0A.B2.19:1)
12/19/2016 6:56:17 AM - [HCM] Creating new HomeSeer device: Fan (0A.B2.19:3)
12/19/2016 6:56:17 AM - [HCM] Creating new HomeSeer device: 6-Button - Button B (0A.B2.19:4)
12/19/2016 6:56:17 AM - [HCM] Creating new HomeSeer device: Night (0A.B2.19:5)
12/19/2016 6:56:17 AM - [HCM] Creating new HomeSeer device: All Off (0A.B2.19:6)
12/19/2016 6:56:18 AM - [HCM] Creating new HomeSeer device: 6-Button - Button Off (0A.B2.19:8)
12/19/2016 6:56:18 AM - [HCM] Creating new HomeSeer device: Track Lighting DOWN (03.96.DA:1)
12/19/2016 6:56:19 AM - [HCM] Creating new HomeSeer device: Track Lighting UP (07.38.EF:1)
12/19/2016 6:56:19 AM - [HCM] Creating new HomeSeer device: Under Cabinet Lighting - Remote (1C.95.CC:1)
12/19/2016 6:56:19 AM - [HCM] Creating new HomeSeer device: Under Cabinet Lighting (07.3D.70:1)
12/19/2016 6:56:19 AM - [HCM] Creating new HomeSeer device: Refrigerator Recessed (1F.74.1B:1)
12/19/2016 6:56:20 AM - [HCM] Creating new HomeSeer device: Sconces (1B.C1.10:1)
12/19/2016 6:56:20 AM - [HCM] Creating new HomeSeer device: Recessed Reading Light (03.8E.F2:1)
12/19/2016 6:56:20 AM - [HCM] Creating new HomeSeer device: Recessed Lights (03.89.2A:1)
12/19/2016 6:56:20 AM - [HCM] Creating new HomeSeer device: Recessed Lights - Bridge Remote (1F.7F.AE:1)
12/19/2016 6:56:21 AM - [HCM] Creating new HomeSeer device: Recessed Lights (03.90.FC:1)
12/19/2016 6:56:21 AM - [HCM] Creating new HomeSeer device: Recessed Lights (07.48.37:1)
12/19/2016 6:56:21 AM - [HCM] Creating new HomeSeer device: Light (07.48.CC:1)
12/19/2016 6:56:21 AM - [HCM] Creating new HomeSeer device: Recessed Lights (07.4C.9A:1)
12/19/2016 6:56:21 AM - [HCM] Creating new HomeSeer device: Recessed Light (Kelly Side) (03.88.79:1)
12/19/2016 6:56:21 AM - [HCM] Creating new HomeSeer device: Recessed Light (Outside Kelly's Room) (03.8A.96:1)
12/19/2016 6:56:21 AM - [HCM] Creating new HomeSeer device: Wall Sconces (07.4A.EF:1)
12/19/2016 6:56:21 AM - [HCM] Creating new HomeSeer device: Recessed Lights (07.3A.1F:1)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Recessed Lights (07.4B.99:1)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Sconce (3D.C2.79:1)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Reading (3D.C2.79:2)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Hallway Path (3D.C2.79:3)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Keypad - 8 Button - Button D (3D.C2.79:4)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Keypad - 8 Button - Button E (3D.C2.79:5)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Keypad - 8 Button - Button F (3D.C2.79:6)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: All Off (3D.C2.79:7)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Security (3D.C2.79:8)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Keypad - 8 Button - Button A/Load (3D.C5.05:1)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Keypad - 8 Button - Button B (3D.C5.05:2)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Keypad - 8 Button - Button C (3D.C5.05:3)
12/19/2016 6:56:22 AM - [HCM] Creating new HomeSeer device: Keypad - 8 Button - Button D (3D.C5.05:4)
12/19/2016 6:56:23 AM - [HCM] Creating new HomeSeer device: Keypad - 8 Button - Button E (3D.C5.05:5)
12/19/2016 6:56:23 AM - [HCM] Creating new HomeSeer device: Keypad - 8 Button - Button F (3D.C5.05:6)
12/19/2016 6:56:23 AM - [HCM] Creating new HomeSeer device: Keypad - 8 Button - Button G (3D.C5.05:7)
12/19/2016 6:56:23 AM - [HCM] Creating new HomeSeer device: Keypad - 8 Button - Button H (3D.C5.05:8)
12/19/2016 6:56:23 AM - [HCM] Creating new HomeSeer device: Recessed Lights - Remote (07.48.D4:1)
12/19/2016 6:56:24 AM - [HCM] Creating new HomeSeer device: Back Door Lights (07.49.2C:1)
12/19/2016 6:56:24 AM - [HCM] Creating new HomeSeer device: Recessed Lights (3E.14.CA:1)
12/19/2016 6:56:24 AM - 0 Matching HS device records were found and updated for the Insteon device database.
12/19/2016 6:56:24 AM - [HCM] Creating new HomeSeer device: Insteon Devices (Group:254)
12/19/2016 6:56:24 AM - [HCM] Creating new HomeSeer device: Interior Lights (Group:21)
12/19/2016 6:56:24 AM - [HCM] Creating new HomeSeer device: All Lights Off (Group:1)
12/19/2016 6:56:25 AM - 0 matching HS device records were found and updated for the Insteon group database.
12/19/2016 6:56:25 AM - Scheduled polling resumed.
12/19/2016 6:56:25 AM - Exit CreateDevices
12/19/2016 6:56:25 AM - I/O(Insteon Protocol) Interface Initialized.
12/19/2016 6:56:25 AM - Waiting to initialize External Devices...
12/19/2016 6:56:25 AM - Exit InitPlugin
