Don't know when HomeSeer will upgrade the Zee S2 to run on a RaspberryPi 3 B I've got a question.
Has anyone taken the Z-Wave card off the Zee S2s RaspberryPi 2 B and put it on the RaspberryPi 3 B along with the SD card? Unless the copy of the OS is quite old it should be able to ID the WiFi interface to one can connect up using WiFI without adding a dongle. Plus the extra speed should hurt.
