Just wrapped up mounting my Nexus on the wall for HSTouch. Pretty stoked at how it turned out. Thought I'd post here to hopefully give some folks some inspiration on their own projects.
Nexus 9 in wall tablet - finished project
Originally posted by S-F View PostLooks nice! Is it made from No. 2 pine? What's the stain you used? How do you turn it on?
We need more details!
If I need to turn on the screen of the nexus manually, I can simply double tap the screen and it turns on (this is built into Android). But, its rare that I need to because I'm using an app called "Motion Detector" that turns on the screen when it detects motion.
Originally posted by jerems View PostHow are you powering the unit? USB adapter?
Sent from my SM-G935F using Tapatalk
For my next one I'm planning to do on the main floor, I'm going to run a sunken outlet with a retrofit single gang box and use a USB plug behind it
Sent from my SM-G930V using Tapatalk
Originally posted by jon102034050 View PostSorry for the delayed reply, been very busy with work! I'm using a 90 degree micro usb plug I got off of Amazon and it just runs thru a tiny hole on the drywall. The other side of this wall is an unfinished mechanical room. It just simply plugs into an outlet there.
Originally posted by jon102034050 View PostRight on, np! Are you planning a similar project? Have anything in the works yet?
Quite daunting when you think of all the possibilities you can wire for but I like the idea of using a couple tablets as user interfaces but the mounting solutions are slim unless you go iPad... Which I won't.
Main thing is making the whole solution wife friendly...haha... Happy wife happy life.
Originally posted by jerems View PostMy wife and I are building a new house so I'm trying to research various ideas so I can pre-release the house accordingly!
https://find-a-poe.com/product/PoE-f...n-PoE-Devices/
Originally posted by ajgyomber View PostI personally would use something like this if you have a POE switch:
https://support.google.com/nexus/for...kNtWO88/?hl=en
Originally posted by ajgyomber View PostNo, it just allows you to use POE to power the microUSB. The tablet itself just thinks it's plugged into the wall. Pretty cool little device.
