Hi, I am a little confused about setting up using my X10 floodlight with motion sensor.
From the post Consolidated Documentation for Insteon PLM Plug-in to use X10 from the Insteon Plug in it said:
"Q: How do I use this plugin to control X10 devices?
A: for HS3, enable X10 on the config page. Create HS devices from the dev mgmt page and use the Save as Insteon X10 button on the insteon tab. If you already have x10 device created, you can use the Update X10 Devices button to reassign any existing x10 device to the Insteon plugin so the plugin can control them."
Which X10 configuration am i enabling? I get the attached error for the X10 Plugin. Is that right?
