Any thought of adding the amount of run time as a device per thermostat? It looks like you could add that pretty easily and would be a great addition for events and such.
Feature request - therm run time
Do you mean cumulative heating/cooling time? There are some other plugins that can track that for you already. I'm completely rewriting much of the plugin for HS3 so I will keep this suggestion in mind.HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
Hardware: Z-NET - W800 Serial - Digi PortServer TS/8 and TS/16 serial to Ethernet - Insteon PLM - RFXCOM - X10 Wireless
Plugins: HSTouch iOS and Android, RFXCOM, BlueIris, BLLock, BLDSC, BLRF, Insteon PLM (MNSandler), Device History, Ecobee, BLRing, Kodi, UltraWeatherWU3
Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.
Here's what I use
Originally posted by skybolt View PostAny thought of adding the amount of run time as a device per thermostat? It looks like you could add that pretty easily and would be a great addition for events and such.Originally posted by reidfo View PostDo you mean cumulative heating/cooling time? There are some other plugins that can track that for you already. I'm completely rewriting much of the plugin for HS3 so I will keep this suggestion in mind.
FWIWAttached FilesSteve
(System configuration is in my profile)
Originally posted by spknapp View PostOrlando - I've attached the script I use for tracking run times on my BeakerStat. This is a modification to the script found at http://board.homeseer.com/showthread.php?t=112678 ; I have modified it to work with BeakerStat. Just follow the install instructions in the zip file or at the original thread.
FWIW
Please don't loose sight of HS2, there will be people that may not upgrade right away or at all until they have to.-Skybolt
