New error message
    New error message
    I had an error message pop up I've not seen before:
    1/18/2013 9:42:25 AM - HSTouch Server - Error accessing thermostat plugin GetTempBeakerStat
    Something to be concerned about? (as if I haven't given you enough to think about )
    Steve
    (System configuration is in my profile)
    New error message
    That's a new one for me too. What were you doing (or what was HS doing) when that showed up? What version of HS and HSTouch are you on?
    Sent from my iPad using Tapatalk HD
      Nothing
      I was working on the documentation for my long post to the other thread, so nothing with HS. That is the only HS log entry after 8:28AM; I don't have any events that would have fired off at such an odd time (9:42:25 AM)
      HSPro = 2.5.0.77, HSTouch = 1.0.0.69.
      Maybe just HSTouch updating its internal info and BeakerStat was busy? Here's the BeakerStat verbose log:
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetTemp() stat=1 sensor=1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetTemp() result=64[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetHeatSet() stat=1 sensor=1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetHeatSet() result=60[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetCoolSet() stat=1 sensor=1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetCoolSet() result=0[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetModeSet() stat=1 sensor=1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetModeSet() result=1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetFanMode() stat=1 sensor=1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetFanMode() result=0[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetHoldMode() stat=1 sensor=1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetHoldMode() result=1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetCurrentMode() stat=1 sensor=1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetCurrentMode() result=0[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetCurrentFan() stat=1 sensor =1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetOperating() stat=1 sensor=1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:10.4211278 : Verbose : STATUS 1 : HSPI.GetOperating() result=False[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:29.1707678 : Verbose : STATUS 1 : Timed poll of thermostat Living Room()[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:29.1707678 : Verbose : STATUS 1 : HSPI.PollDeviceManual: devref=1149 Thermostat=Living Room[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:29.1707678 : Verbose : STATUS 1 : RadioThermostatWiFi.QueryThermostat: thermostat=Living Room uri='/tstat'[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:29.1863925 : Verbose : STATUS 1 : busywait waiting for thermostat 172.16.0.121(Living Room) to be free.[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:29.1863925 : Verbose : STATUS 1 : busywait done waiting for thermostat 172.16.0.121(Living Room). continuing on.[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:29.1863925 : Verbose : STATUS 1 : Thermostat Living Room is now busy[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:29.3582642 : Verbose : STATUS 1 : RadioThermostatWiFi.QueryThermostat: stat=Living Room Response content length is -1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:29.3582642 : Verbose : STATUS 1 : RadioThermostatWiFi.QueryThermostat: stat=Living Room Content type is application/json[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:29.3582642 : Verbose : STATUS 1 : RadioThermostatWiFi.QueryThermostat: stat=Living Room Response status code = OK(OK)[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.8582354 : Verbose : STATUS 1 : RadioThermostatWiFi.QueryThermostat: stat=Living Room Response = '{"temp":64.00,"tmode":1,"fmode":0,"override":0,"hold":1,"t_heat":60.00,"program_mode":1,"tstate":0,"fstate":0,"time":{"day":4,"hour":9,"minute":41},"t_type_post":0}'[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.8582354 : Verbose : STATUS 1 : Thermostat Living Room is now unbusy[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.8582354 : Verbose : STATUS 1 : RadioThermostatWiFi.Poll() result={"temp":64.00,"tmode":1,"fmode":0,"override":0,"hold":1,"t_heat":60.00,"program_mode":1,"tstate":0,"fstate":0,"time":{"day":4,"hour":9,"minute":41},"t_type_post":0} stat=Living Room[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.8582354 : Verbose : STATUS 1 : HSPI.PollDevice: return=Temperature: 64°F Setpoint (Heat): 60 Mode: Heat Mode (Operating): Idle Fan: Auto[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.8582354 : Verbose : STATUS 1 : HSPI.PollDeviceManual() updating root device [7 value=Heat[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.8738601 : Verbose : STATUS 1 : HSPI.PollDeviceManual() updating fan device [1 value=Auto[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.8738601 : Verbose : STATUS 1 : HSPI.PollDeviceManual() updating operating device [2 value=Heat[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.8738601 : Verbose : STATUS 1 : DEBUG GetCurrentMode() = 1[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.8894848 : Verbose : STATUS 1 : HSPI.PollDeviceManual() updating currentModeStatus device [3 value=Idle[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.8894848 : Verbose : STATUS 1 : HSPI.PollDeviceManual() updating setpoint device [5 value=6000[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.8894848 : Verbose : STATUS 1 : HSPI.PollDeviceManual() updating hold device [4 value=On[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.9051095 : Verbose : STATUS 1 : HSPI.PollDeviceManual() updating override mode device [6 value=Off[/COLOR][/SIZE]
      [SIZE=1][COLOR=black]18/01 09:42:30.9207342 : Verbose : STATUS 1 : Successfully polled thermostat Living Room[/COLOR][/SIZE]
      Looks fairly innocent.
      Hmm...
      Steve
        New error message
        The plugin wasn't busy, and the HS and thermostat interfaces are on different threads anyway, so it should always be available. Let me know if this happens again. I'll make sure I am running the same versions in my testing too.
          Thanks, Reid.
          Steve
