Cross-posting this issue that I have submitted to the helpdesk in the hope that someone else has experienced and solved this issue with ADIO-100:
When the ADIO add-in starts up, I get this error in the log file:
ADIO-100 ERROR Expected Response from Unit Not Received For Command z
When I execute commands to turn on or off a digital output, I see these statements in the log file:
May-27 2:04:12 PM Device Control Device: BIT0 ADIO-100 ADIO Unit 1-BIT0 to Off (0) by/from: CAPI Control Handler
May-27 2:04:00 PM Device Control Device: BIT0 ADIO-100 ADIO Unit 1-BIT0 to On (5) by/from: CAPI Control Handler
I found that the ADIO module is manufactured by Integrity Instruments (232M100 Series IO Module), downloaded their manual and the EZTerm program that they provide on their website.
Using the EZTerm program, (on COM4 (the serial port that the ADIO is connected) and at 9600 baud):
I can do the following:
T0000 - sets all bits to Output
G - verified all bits are set to Output
Connect an LED (with resistor in series) between digital BIT 0 and GND:
O0001 - the LED lights!
O0001 - the LED turns off
Then, I disconnect the LED and convert digital BIT 0 to input:
T0001 - sets Bit 0 as input
G - verifies 0001
I - returns 0000 - confirming that all inputs are 0 (off)
Apply 5VDC to Pin 0:
automatically displays I0001 on EZTerm console
Remove 5VDC from Pin 0:
displays I0000 on EZTerm console
So I can verify that the ADIO unit is functioning and communicating correctly with the Homeseer Hometroller S3.
However, when I configure the same Bit 0 as an output and get the same LED to turn on (just stays off) from Homeseer....nothing!
FYI...I just upgraded to Homeseer 3.0.0.177 and it made no difference. The version of the ADIO-100 plug in that I am running is 3.0.0.29.
G - verifies 0001
