Hi Spud,
I just ordered a few of the new Simply Automated UPB 3-Speed Fan Controllers and wanted to see if you could set them up so they import correctly int the plugin.
Product Link Here:
http://www.simply-automated.com/prod...ller_white.php
Product Sheet Here:
http://www.simply-automated.com/docu...-W)_140404.pdf
Manual Here:
http://www.simply-automated.com/docu...ide_140415.pdf
It essentially is a 4 Button Controller with Off/Low/Medium/High options. It also has an ability to switch (not dim) a light which I am not using. That said, each button is also a scene switch and activates a scene if preferred. The Scenes are working as expected and imported and operate fine. I just cant seem to get it to show up as a consolidated device. Each button on the device is a separate channel import as shown shown in the attachment.
I have also attached the .UPE File information for that controller. Please let me know if you can help or if you need anything else from me.
-Travis
Product Link Here:
Product Sheet Here:
Manual Here:
-Travis
