Wireless Doorbell Button
    I have ACRF processor and W800. I'm looking for a simple wireless doorbell button that will be picked up by the W800. I have seen the "big red" button, but really want something more elegant.
    Any help appreciated.
    Tom
    If you can hide a ds10a you could use any button you wanted by hooking the doorbell contacts to the ds10a wire.
    This could be very simply done if there was an existing doorbell wire !
    I use the big red button so everyone can see it (from about 300' away) .
    Neil
    Neil
    Newmarket Ontario
      Neil,
      My problem is the existing wired doorbell wires are broken inside a brick wall so I cant get to them/use them/replace them...
        Oh oh ! Broken wires not good !
        Maybe you could drill thru the door jamb and then run very thin wire behind the door casing on the inside to where your ds10 could be mounted and hidden........ might need a router to cut a groove in the back of the casing and make sure you don't nail thru the wire.
        ..........or tear apart one of the dollar store panic alarm kits or window alarm kits to see if anything could be salvaged from the kit ?
        .........or take apart your "big red" button and paint it with acrylic paint and an airbrush to match your brick colour.
        Neil
        Neil
        Newmarket Ontario
