As I mentioned before and confirmed by U5tabil, you can set the volume and tone using an HS3 Event.
Support for Aoetec Aeon Labs Siren - Solved!
Originally posted by slbuck View PostWith the ability to set a configuration parameter as a z-wave action, I thought I'd list out the decimal values to get the various siren and volume combinations. I can now use these in events to change the Aeon siren on the fly. When sending the configuration parameter 37, the siren will immediately turn on, so keep that in mind when creating events with the siren.
I have a timeout event for the siren which turns it off if it's been on for more than 10 minutes. The problem is, HS never sees the siren as being on when it's activated by a configuration parameter. Normally, with z-wave devices, you would set the configuration parameter, and then control the device by turning it on, but this siren doesn't act that way.
We found this out one time when the siren was activated via configuration parameters, but for some reason the z-wave off signal never made it and so it happily blasted out the siren for about 3 hours.
What I ended up doing was any time I called an event to turn on the siren, I added a z-wave poll of the siren to make sure that the device showed correctly so that my timeout event could continually try to turn it off after 10 minutes if for some reason it remains on.
Originally posted by slbuck View PostOne thing I discovered when activating the siren by setting the configuration parameters: There is no z-wave notification to HS. Also, there is no default polling interval set when initially including the siren.
Originally posted by JamesTatePa View PostThanks for all of the helpful information. I have my siren where I can run an event to turn each of the 5 sirens on, but don't seem to be able to turn it off with HomeSeer. Having to manually push the button on the siren. Can someone show me how they have it configured to HS.
You'll also want to make sure that parameter 80 is set to 1 so that the status of the siren will update to ON when you set parameter 37 to activate it. I have a timeout event that will silence the alarm if it runs for too long.
Still doesn't work for me. I set parameter 80 to a 1. Then ran my event. The siren did not shut off after 1 second so I tried to manually turn it off and that did not work. Had to push the button on the alarm to turn it off. Here is part of the log showing where the event tried to turn if off after 1 second and where I tried to manually turn it off.
Mar-08 8:52:43 PM Device Control Device: Z_Controls Office Aeon Labs Siren - Node 14 to Off (0) by/from: CAPI Control Handler
Mar-08 8:52:19 PM Device Control Device: Z_Controls Office Aeon Labs Siren - Node 14 to Off (0)
Mar-08 8:52:18 PM Event Event Trigger "Test Siren 5 Test 1 second 88 dB"
Mar-08 8:52:18 PM Event Event Test Siren 5 Test 1 second 88 dB triggered by the event page 'Run' button.
I am also going to post my event.
Originally posted by JamesTatePa View PostStill doesn't work for me. I set parameter 80 to a 1. Then ran my event. The siren did not shut off after 1 second so I tried to manually turn it off and that did not work. Had to push the button on the alarm to turn it off. Here is part of the log showing where the event tried to turn if off after 1 second and where I tried to manually turn it off.
What version of the z-wave plugin are you running? Make sure it's up to date. What do you show for your siren's root device node (under Plug-Ins-->Z-Wave-->Node Information. I've attached my info here. If you don't have the secure commands, you will need to re-add the siren while it is located close to the controller. I typically have my secure devices associate within about 15 feet of the controller.
