Originally posted by Rotech
View Post
TUTORIAL: Setup your Amazon Echo UK to talk to HomeSeer (Workaround)
Originally posted by Croccy22 View PostYour Utterance line is wrong in this one.
When I try to enable it and enter my user and pword and ID for the skill, it's says it time out and will be redirecting in X secs.Hector
Win.2003 OS, HS3
MyTrigger,ACRF2,W800,Zwave
AP800,Honeywell Stat
Timeout redirecting in 5 seconds
Hi guys,
I've loaded all of the settings in the instructions (including the two mods to required) and get to the final screen in the developer part of the amazon site where it shows the service emulator. I enter the start command and it returns the correct reply stating that the account needs to be linked/activated.
I then go to my Alexa app on iOS and enter my log in details - along with the vender ID, it then comes straight back with the timeout error redirecting in 5 seconds .... returning me back to the login screen again (minus the option to add the vendor ID).
Is there anything I am doing wrong - or anyone can suggest to help.
Best wishes,
Jay
Hi guys ...... I have a suspicion I know what may be causing my account linking issue .....
In the setup it has a box stating:
Privacy Policy URL
Link to the Privacy Policy for this skill. This is mandatory for account linking.
I can't see anywhere in the instructions where it provides the mandatory URL I seem to need.
Am I missing something?
Cheers,
Jay
I to am having the same problem. I have set this up before and it worked no problems but now it will not link. Any help would be great.
GreigZwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Hi guys,
Has anyone found any fix for the timeout error redirecting in 5 seconds issue when trying to link the account ?
I've tried literally everything, including deleting the skill and starting from scratch. I've ensured that literally every entry in the skill is copied and pasted from the instructions to ensure there are no typos. I have also implemented the two fixes mentioned at the start of the thread to ensure these are causing any issues.
I'm really desperate to get it working !
Thanks ever so much for reading this,
Jay
Jay
No I to am stuck without the Skill and Jon's script an I tested it before and really liked it but I deleted the Skill and can no longer add it again.
Greig.Zwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Originally posted by jon00 View PostI'm wondering if a call to Amazon developer would assist?
FYI, you can now use my script in local mode (no skill required) for control if you ignore Alexa's response. You could even setup your own dev skill that does nothing so that Alexa just responds with OK.
I guess other than following the instructions to the letter, I don't understand the mechanics behind how the system works, so assume that any call to the developer support at Amazon would render me with questions which would leave me clueless for answers !
Jay
Cheers
Greig.
Sent from my SM-G925F using TapatalkZwave = Z-Stick, 3xHSM100� 7xACT ZDM230, 1xEverspring SM103, 2xACT HomePro ZRP210.
Scripts = Various
Originally posted by enigmatheatre View PostI have the bridge working but want your script to so will give local mode a go tonight if I get time.
Cheers
Greig.
Just in case you still have the account linking issue .... Jon00 has been incredible and had a look at my Amazon config for me. He's compared it with his own and suggested that there were a couple of things that I could try - and I'm happy to say that I'm up and running at long last.
The things he suggested were:
Changed the Skill name from "HomeSeer" to "Homeseer"
Also:
Added the privacy policy as:
http://www.homeseer.com/privacy-policy.html
I suspect that it is the latter that has fixed the problem.
It wasn't required in the setup instructions, but I think must now be required by Amazon.
Thanks again to Jon for bein a true star and helping me. Hopefully if anyone else has the same problem, the above will fix it for them!
Best wishes,
Jay
Also:
Best wishes,
Jay
Thanks I did see his post and changed my setup but still no luck. I did not spend long on it so maybe I will try again later.
Greig.
Scripts = Various
