I know there is an article that explains how to "fix" this by changing port, but i've been running it for years without issue, then all of the sudden either a windows update, or homeseer update caused this to no longer work.
Has anyone else seen this recently?
~!~Warning~!~Error starting web server, port in use? Are you running a web server on the designated port? Edit settings.ini in the Config folder and change gWebSvrPort=## to a different port #. An attempt was made to access a socket in a way forbidden by its access permissions
