dont know if it was mentioned, but if you have a userid/pwd on your homeseer, addin the repo.xml to squeezecenter will fail (bad authorisation) manual install worked though.
SqueezeBox plugin V2.0.0 beta 2
Well not even...
The hstclient on the iphone is in the booting process and then at the moment it should say building screens ( thats after getting data ) it crashes back to springboard.
Do you want me to load it as a button in hst and deploy the pictures and see if it still works ?
Picture loads up and shows fine at photoshop and beside beeing alpha tranparant i dont see any strange things.
But it raises some questions here :
- is there a specific reason to use alpha transparancy in this picture ?
- is it possible to do a test and change the cover.png to a cover.jpg ( i mean in your code ) to see or it changes something in the problem i expierence ?
I also heard about some issue that the .png keeps on stage and looks like its layered, because the see the cover.png halve thru the album artwork wich might a thing to check. ( removal of cover.png when albumart.jpg is loaded )
Cover.png works fine in all cases i tried.
I think you have to look in a other direction. Atleast thats my opinon....
In the standard itouch template is a music page but that doesnt call the cover.png
there isn't squeezebox support either so in my case it makes no sence.
As far i can think of it must be something in the init sesion of the iphone/pod/pad in combination of the musicapi and the sq plugin.Last edited by Robin_f; April 18, 2010, 04:09 PM.
FWIW, I have the same experience with both a Touch and Iphone 3G..... HS Client starts to load and then dies, back to icon screen before it can ever cache the screens. Never had it work, but I had SqeeuzePlugin installed since day 1 of my adventure in HomeseerLand.
- Jim -My home is smarter than your honor roll student.
I posted a new beta revision with several fixes/enhancements. Since the jpg image was smaller than the png, I switched to the jpg version (it is not as nice but will save space on mobile devices). Otherwise still trying to figure out why iPhones / iTouch clients don't properly start upon connection. Did I understand correctly that in non of your cases, HSTouch screens did not include any information from SqueezeBox devices/plug-in?
No change here,
still going back to springboard ( apples home page ) after the getting data messega on hst iphone platform.
And you understood me right. Problem occures also when there is no sq player attached to the template.
But as far i understood hs tells hst anyway about attached players.
and to me it seems hst iphone client stops on this somehow. As it never shows building screens. ( wich would be the step after getting data )
As everything works fine when i disable the plugin there is no other option for me than trace it back to the things i mention.
Somehow it must be a combination of things as not everyone has this problem.
I keep getting the following error over and over. Any ideas?
<TABLE border=0 cellSpacing=2 cellPadding=0 width="100%"><TBODY><TR><TD class=LOGDateTime0 noWrap align=left>4/26/2010 6:57:19 AM </TD><TD class=LOGType0 colSpan=3 align=left>SqueezeBox Error </TD><TD class=LOGEntry0 colSpan=8 align=left>An unexpected error occured in the CurrentArtworkFile function/subroutine: [System.ArgumentException: 'plugins/Sounds/html/images/icon.png' is not a valid remote file address. A valid address should include a protocol, a path and a file name.Parameter name: address at Microsoft.VisualBasic.Devices.Network.GetUri(String address) at Microsoft.VisualBasic.Devices.Network.DownloadFile(String address, String destinationFileName, String userName, String password, Boolean showUI, Int32 connectionTimeout, Boolean overwrite, UICancelOption onUserCancel) at Microsoft.VisualBasic.Devices.Network.DownloadFile(String address, String destinationFileName, String userName, String password, Boolean showUI, Int32 connectionTimeout, Boolean overwrite) at HSPI_SQUEEZEBOX.hspi_player.GetCurrentArtworkPath(String path)]</TD></TR></TBODY></TABLE>
This error is trapped by the plug-in when it cannot download an album cover. It is displayed in the log to capture it and will instead return a default cover album image. My guess is that one of your players is referring to this icon in its playlist, but I could be wrong. I have not seen that SBServer returns path like this one 'plugins/Sounds/html/images/icon.png' as a album cover page. Can you try clearing all playlists for all players? If you find which playlist entry creates it let me know and I can try to reproduce it.
