IanIreland: I cant find the command spec for the CX-A5000 so I cant check what differs and if I might make the plugin compatable. Search around and see if you can find it, should be something YNCA command spcification something.
mystic860: Isnt AV1-7 the HDMI inputs?
sylcoucou: Ill look into the Zones too.
Wondering if I should ask the amplifier at plugin start-up and generate the devices depending on which amplifier is there or just generate devices for the most advanced amplifier. But I only have an hour or two a week to spend on this, so I want to make whats mostly needed first.
