What was the difference between .126 and .128? I checked the sticky page on revisions but the last one listed was .126.
Delays with version 3.0.1.124
128 has better handling of polling devices when a battery device wakes up. If it goes to sleep too early it will immediately stop polling. Also, when adding a device, polling is never enabled on it (except for older thermostats).
Originally posted by bebaldin View PostWhat was the difference between .126 and .128? I checked the sticky page on revisions but the last one listed was .126.
Rich overall on 128 I have seen a vast improvement. I did have a couple delays on my test I have been running, but never noticed any issues in days to day operations.
I am no investigating deeper on my side as the delays I have seen are coinciding a few seconds after my aeotec house meter tries to update. Looks like I might be having a faulty device. I'll keep you posted, but overall my experience has vastly improved.
Originally posted by waynehead99 View PostRich overall on 128 I have seen a vast improvement. I did have a couple delays on my test I have been running, but never noticed any issues in days to day operations.
I will enable polling again and see what happens.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
I have two older hsm100's battery devices that I'm trying to get rid of. Removed one and replaced with hsm 200. Deleting the devices for one and re-importing and scanning from znet has started this disaster. Enable/disable of zwave plugin didnt help, reboot znet didn't help. Had to restart Homeseer to get errors to stop.
Processing data buffered by the interface while it was disconnected.
Jun-10 10:05:38 AM Z-Wave Z-Net: Z-Wave Ethernet at IP 192.168.42.39, connected to interface ok.
Jun-10 10:05:33 AM Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.42.39...
Jun-10 10:05:32 AM Z-Wave Error Z-Net: The Z-Net interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
Jun-10 10:05:25 AM Z-Wave Z-Net: Getting node information from controller...
Jun-10 10:05:25 AM Z-Wave Z-Net: Processing data buffered by the interface while it was disconnected.
Jun-10 10:05:25 AM Z-Wave Z-Net: Z-Wave Ethernet at IP 192.168.42.39, connected to interface ok.
Jun-10 10:05:20 AM Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.42.39...
Jun-10 10:05:19 AM Z-Wave Error Z-Net: The Z-Net interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
Jun-10 10:05:14 AM Z-Wave Z-Net: Getting node information from controller...
Jun-10 10:05:14 AM Z-Wave Z-Net: Processing data buffered by the interface while it was disconnected.
Jun-10 10:05:14 AM Z-Wave Z-Net: Z-Wave Ethernet at IP 192.168.42.39, connected to interface ok.
Jun-10 10:05:09 AM Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.42.39...
Jun-10 10:05:09 AM Z-Wave Error Z-Net: The Z-Net interface did not respond to the request for the controller capabilities - it may be disconnected or malfunctioning (3).
Jun-10 10:05:00 AM Event Running script in background: /home/william/HomeSeer/scripts/WakeUp.vb
Jun-10 10:05:00 AM Event Event Trigger "Alarm Clock Check Alarm"
Jun-10 10:04:56 AM Z-Wave Z-Net: Getting node information from controller...
Jun-10 10:04:56 AM Z-Wave Z-Net: Processing data buffered by the interface while it was disconnected.
Jun-10 10:04:56 AM Z-Wave Z-Net: Z-Wave Ethernet at IP 192.168.42.39, connected to interface ok.
Jun-10 10:04:51 AM Z-Wave Warning Trying to re-connect to Ethernet interface at IP 192.168.42.39...
Jun-10 10:04:50 AM Z-Wave Z-Net: Getting node information from controller...
Jun-10 10:04:50 AM Z-Wave Z-Net: Processing data buffered by the interface while it was disconnected.
Jun-10 10:04:50 AM Z-Wave Z-Net: Z-Wave Ethernet at IP 192.168.42.39, connected to interface ok.
Jun-10 10:04:50 AM Z-Wave Error Z-Net: The Z-Net interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
Jun-10 10:04:50 AM Z-Wave Error Z-Net: Exception transmitting to IP 192.168.42.39: Write failure
Jun-10 10:04:36 AM Z-Wave Z-Net: Getting node information from controller...
Originally posted by bebaldin View Post.128 has proven to be a regression for me. As soon as I went from 126 to 128, the delays started up immediately. If someone can provide me a link to 126 Linux to roll back to, I would appreciate it.- Manually check every Z-Wave device for polling. Unless it does not support instant status disable polling.
- Pay special attention to energy, multi sensors and thermostats. The problems in my system were clearly related to polling Aeotec smart strips. Polling a device that reports automatically seems to cause a problem. On devices that report and have a battery, only poll the battery child.
- Temporarily disable polling altogether on the Z-Wave config page.
My system has been perfect since I did all that yesterday. I found that a rescan of my devices last summer added 20 minute polling to about a third of my devices, none of which require polling.
I do think Rich still needs to figure out why polling can bring the Z-Wave network to a dead halt, but the above steps made mine work again.
I enabled Z-Wave polling again this morning and my system is still running without delays.
All of the HS downloads are at https://homeseer.com/updates3HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Just to add to Randy's list, if you are indeed polling, be sure to stagger the poll times. If they are all set to 10 mins, that might cause issues.
Sent from my Galaxy S7 Edge using TapatalkHS4Pro on a Raspberry Pi4
HSTouch Clients: 1 Android
Thanks Randy; How you figured this out I'll never know.
Originally posted by rprade View PostIt is interesting how the same version can behave differently for different people. You might want to go through the steps that I did which made a huge improvement under .126
All of the HS downloads are at https://homeseer.com/updates3Don
Originally posted by Rvtravlr View PostRich,
Could we have a bulk operation to enable/disable polling similar to changing floor/Room?
And, if we can, can we also add, enable/disable voice?
Polling you can select the disable polling from the zwave plugin (go to manage plugins and click on the zwave plugin. It's almost like its a hidden menu).
For those still having issues with delays, I would really recommend digging into your network. I am finding my delays now are related to faulty devices. Some are just plain bad, but some if I exclude and include, seems to fix the issue.
Not to say there still isn't a problem, because I do think some of the stuff I am doing, I shouldn't have to (except for physically bad devices), but it has helped me greatly.
Originally posted by donstephens View PostThanks Randy; How you figured this out I'll never know.
We have not seen a delay at all since Thursday, but after I enabled polling this morning, there are two instances of delay in my test events. If they continue, I will capture debug logs and send them to rich Monday.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Okay, I gave up on .128.
Back on .110 I have more delays than I used to, but the situation is bearable.HSPro 3.0.0.458, Z-NET with Z-wave plugin 3.0.1.190, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
