Can anybody explain to me why I have the light at my bedroom turns on everyday around 23pm although I deleted all the default events in Homeseer and now nothing should work automatically ! could it be that something to do with macros and things has been saved to my controler (CM 11 ) because it only works when the CM 11 connected to the wall ? please Help !
Stopping lights from turning on!
alhakeem2001Tags: None
Personally I would remove the batteries from the CM, and forget about them - HS does not need nor like them. Unplug the unit for at least 30 mins, then plug it in again.
BTW if you are having trouble with CM's a good way to get it to behave is to unplug it completely (Fron mains and HS) for about 30 mins.
Oh after doing either it is a good idea to restart HS.sigpic
Originally posted by Rupp View PostSounds like you need to clear the CM11A's memory. The only way I know to do this is with the Active Home Software. A Bing search may turn up an easier way.
In the early days of HS (V1) there was a script, or may have been exe, on this BBS to clear the memory. Tried to search for it but nothing turned up.sigpic
