Where is the Infrared Device I created?
    I have successfully set up a USB-UIRT in Homesee. Under tools/infrared devices I have successfully created a device and taught its, an infrared command. When I use the blue "send" button HomeSeer successfully activates the infrared device and the television I am controlling respondents properly..
    However I cannot find this device to HomeSeer to use it. I believe this should show up as a new device.? I hope I am not missing something basic. :-)
    Thank you in advance. Any tips appreciated.
    Kevin
    The USB-UIRT doesn't not give you devices, instead what it gives you is the ability to trigger events on a IR match or event actions that can used to send IR commands. It's all event driven as opposed to using devices.
    Marty
