attached is a version of the EnvisaLink plugin for HS3 (for a HS2 version go to this thread)
Installation:
Please report any bug. Thanks!
Changes to v3.0.0.40
- Fixed problem with triggers when running multiple instances of the plugin.
Changes to v3.0.0.39
- Fixed bug causing system to switch from Armed Stay to Armed Away when the plugin starts
Changes to v3.0.0.38
- Fixed bypassed status devices which were out of sync at startup or after disarm.
Changes to v3.0.0.37
- Added additional possible zone types: CO, Water and Glass Break
Changes to v3.0.0.36
- Fixed "Verbose Trouble Status" trigger
Changes to v3.0.0.35
- Added "Verbose Trouble Status" trigger
- Possibility to rename controls (Arm Stay, Arm Away, Disarm, etc....) to anything you want.
Changes to v3.0.0.34
- Added SendKeystrokeString scripting function
- Added possibility to use a replacement variable as the parameter of "Send Keystroke String" action and scripting function
Changes to v3.0.0.33
- Fixed error in config page when some zone devices are missing
Changes to v3.0.0.32
- Added possibility to create additional "Zone Bypassed"devices that show if a zone is Bypassed or Active.
- Added possibility to rename and set the type of zones from the config page.
- The "User Access" string is now set to "Armed by System" when the system is armed from HomeSeer.
Changes to v3.0.0.31
- Added option to not recreate missing devices on startup
- "User Access" device value is now updated with the DSC user id.
Changes to v3.0.0.30
- Added possibility to run multiple instances of the plug-in
Changes to v3.0.0.29
- Added timeouts to the TCP connection
- Added "Log to File" option
- Support for 10 characters password for EVL4
- Changed device icons to the default HS icons
Changes to v3.0.0.28
- Fixed Copy/Paste of actions and triggers
- added timestamp in logs to console
Changes to v3.0.0.27
- When DSC user is not configured as a HS user, the User Access device will now show "Armed/Disarmed by user #xx"
Changes to v3.0.0.26
- Added "Send Keystroke String" action
Changes to v3.0.0.25
- Added "Command Output Pressed" trigger
Changes to v3.0.0.24
- Added the possibility to select "Any" for all the triggers that have a zone or partition as a parameter
Changes to v3.0.0.23:
- Fixed problem with some messages that the plugin couldn't understand because the size of the message was longer than expected
Changes to v3.0.0.22:
- Fixed problem on config page which prevented log level to be saved in some specific situations.
Changes to v3.0.0.18:
- Added "Enable Log For Device Status Change"and "Disable Log For Device Status Change" actions
- Added some logs when User Access device status changes.
Changes to v3.0.0.17:
- Added "Arm Zero Entry Delay" button on partition device
- Added possibility to prevent status change log, configurable at device level.
Changes to v3.0.0.16:
- avoid disconnecting on unknown command received
Changes to v3.0.0.15:
- Log partition and zone status changes at info level
Changes to v3.0.0.14:
- Fixed message parsing when there is no timestamp at the beginning ( EnvisalinkZoneTimerDump)
Changes to v3.0.0.12:
- Added "Trigger PGM Output" Action
- Truncate password to 6 characters max.
Changes to v3.0.0.11:
- Cosmetic changes
Changes to v3.0.0.10:
- Added a "User Access" device showing the name of the user that last armed or disarmed the panel
- Added possibility to assign several DSC user codes to the same HS user
Changes to v3.0.0.9:
- Added zone and partition numbers in Address field
- Added a user parameter to the "User Opening" and "Use Closing" triggers so that an event can be triggered when a specific user arm or disarm the system.
Changes to v3.0.0.8:
- Fixed shutdown of plugin.
Changes to v3.0.0.7:
- Added "Exit Delay in Progress" and "Entry Delay in Progress" as partition possible status
Changes to v3.0.0.6:
- Changes to make the plugin work on linux.
Changes to v3.0.0.5:
- Added action "Sync Alarm Time" to sync alarm time with system time
- Ignore messages that fail to be parsed, and log them as warnings
Changes to v3.0.0.4:
- Added following partition statuses: "Armed Away", "Armed Stay", "Armed Stay - Zero Entry delay", "Armed Away - Zero Entry delay", "Ready - Force Arming Enabled"
- Added root device, and set all other devices as children of root
Changes to v3.0.0.3:
- Added "Ring Detected" message as a trigger
Changes to v3.0.0.2:
- Fixed "Ring Detected" message which was causing error when received.
- Added link to this forum
Changes to v3.0.0.1:
- Better error handling for connection and password issues
- Added EnvisaLink icon as default device image
Installation:
- download the zip attached to this post and save it in the HS3 application folder /updates3/zips
- download the file named updater_override.txt attached to this post and save it in the HS3 application folder.
- go to the "PLUG-INS > Manage" page and click the "Update Listing" button, then click "Additional interfaces > Test Plugin" and check the EnvisaLink line.
- click the "Download and Install" button
- enable the plugin from the "PLUG-INS > Manage" page
- delete updater_override.txt from your HS3 application folder
- Cosmetic changes
