firmware ad2usb?
    firmware ad2usb?
    I am upgrading to HS3. I was an early adopter of the ad2usb and figure I should check the firmware. I saw a cautionary note about not using the plugin to do this. I forget where I get the firmware and the utility to upgrade it. Thanks
    nutech started a new site for the ad2usb: alarmdecoder.com
    everything you need to update the firmware is there
    Mark
    HS3 Pro 4.2.19.5
      Anyone know if AD2USB is still supported? Nutech is offline, as well as that alarmdecoder site.
        I sent an email to sean, i'll let you know what I get back
        Mark
        HS3 Pro 4.2.19.5
          looks like they are back online...just a down VM
          Mark
          HS3 Pro 4.2.19.5
            Thank you! Confirming it's online and I was able to download a firmware update. Much appreciated.
