Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > Eric Fetty Plug-Ins > Liftmaster MyQ Plug-in (3P)
Liftmaster MyQ Plug-in (3P) Discussion of Liftmaster MyQ plug-in
  #41
Old September 13th, 2017, 10:37 AM
kingfetty's Avatar
kingfetty kingfetty is offline
Seer Master
Thanks for letting me know... I'm using the debug dump to try and recreate the issue and see why it might be doing this.
  #42
Old September 18th, 2017, 04:08 PM
Mario23's Avatar
Mario23 Mario23 is offline
Seer Master
The latest version wasn't working for me then I realized that at some point, the login info was removed from the config page. I put it back in and its working. Just FYI Tks
HSPro on a Supermicro Atom|Z-Net
Elo touchscreen client, Android Phones and Tablets, Xbox One
Global Cach/Ultra-GCIR | Etherrain | Jon00 | Sonos | Blue Iris | URC Whole Home Remotes | Philips Hue | Nest | Grandstream | Leviton | Aeon Labs | Cooper | Kwikset | Evolve | Envisalink/DSC | Amazon Alexa/IFTT
  #43
Old September 20th, 2017, 05:26 PM
baudi baudi is offline
Seer Deluxe
Running version 1.1.17244.94, the plugin has stopped working for me again. It won't open or close the door, nor will it report on the status of the door when I use the Chamberlain website to open or close it.
Current Date/Time: 9/20/17 9:06:14 PM
HomeSeer Version: HS3 Standard Edition 3.0.0.362
System Uptime: 0 Days 9 Hours 27 Minutes 7 Seconds
IP Address: 192.168.1.17
Number of Devices: 271
Number of Events: 75
Available Threads: 400
Enabled Plug-Ins
2.0.35.0: BLLAN
3.1.1.19842: Blue-Iris
2.0.22.0: BLUPS
3.0.0.33: EasyTrigger
1.0.16302.20: EventGhost
3.0.0.20: ImperiHome
3.0.6.3: Insteon
1.1.3.1: JowiHue
3.0.0.5: KMS
1.1.17244.94: MyQ
1.0.0.5: Restart
3.1.0.18: Sonos
3.0.0.73: weatherXML
3.0.1.130: Z-Wave
David
  #44
Old September 21st, 2017, 10:19 PM
ALittleSlow ALittleSlow is online now
Seer
Error connecting to Web Service over the internet
Now getting this error. My internet is working fine. Ideas? I submitted debug data in case it helps.
Sep-21 22:08:21 MyQ Warning Disabled LiftMaster Service!
Sep-21 22:08:21 MyQ Warning You have no services enabled, please goto the MyQ plugin settings and configure a service and enable the checkbox.
Sep-21 22:08:20 MyQ LiftMaster: Too many login failures, disabling service + LiftMaster permanently!! You will need to correct your login credentials and re-enable the service in the MyQ settings.
Sep-21 22:06:52 MyQ Unexpected JSON values returned from login or login service unreachable from Homeseer. Please check your connection to the web service from the homeseer box.
Sep-21 22:06:52 MyQ Error connecting to Web Service over the internet: System.Net.WebException: Error getting response stream (Write: BeginWrite failure): SendFailure ---> System.IO.IOException: BeginWrite failure at System.Net.Sockets.NetworkStream.BeginWrite (System.Byte[] buffer, Int32 offset, Int32 size, System.AsyncCallback callback, System.Object state) [0x00000] in :0 at Mono.Security.Protocol.Tls.RecordProtocol.BeginSendRecord (ContentType contentType, System.Byte[] recordData, System.AsyncCallback callback, System.Object state) [0x00000] in :0 at Mono.Security.Protocol.Tls.RecordProtocol.SendRecord (ContentType contentType, System.Byte[] recordData) [0x00000] in :0 at Mono.Security.Protocol.Tls.RecordProtocol.SendAlert (Mono.Security.Protocol.Tls.Alert alert) [0x00000] in :0 at Mono.Security.Protocol.Tls.RecordProtocol.SendAlert (AlertDescription description) [0x00000] in :0 at Mono.Security.Protocol.Tls.SslStreamBase.AsyncHandshakeCallb ack (IAsyncResult asyncResult) [0x00000] in :0 --- End of inner exception stack trace --- at System.Net.HttpWebRequest.EndGetRequestStream (IAsyncResult asyncResult) [0x00000] in :0 at System.Net.HttpWebRequest.GetRequestStream () [0x00000] in :0 at System.Net.WebClient.UploadDataCore (System.Uri address, System.String method, System.Byte[] data, System.Object userToken) [0x00000] in :0 at System.Net.WebClient.UploadData (System.Uri address, System.String method, System.Byte[] data) [0x00000] in :0
  #45
Old September 21st, 2017, 11:58 PM
kingfetty's Avatar
Seer Master
Check your settings for the plugin and make sure you have the correct check box selected.
BTW.. I have an update coming out this weekend that fixes quite a few reliability bugs.
  #46
Old Yesterday, 10:47 AM
Seer Deluxe
Quote:
How do we know which boxes to select?
HTML code is Off
Arduino plugin locks up HS3 web service rich_jones123 Arduino Plugin (3P) 2 May 3rd, 2016 06:29 PM
Spotify online music service, someone able to do a plugin? lunkan HomeSeer General Discussion Area 22 July 8th, 2011 01:10 PM
How to run Media Plugin when HS is a service williamwyoung Windows Media Player 0 December 14th, 2006 12:01 PM
MR26A plugin fails to open port when HS is a service JimBob HS2 / HSPRO 23 December 13th, 2005 11:55 AM
HS 2 as a service and MR26A plugin simanco HS2 / HSPRO 1 September 16th, 2005 03:06 AM
