I am using Homeseer on a Raspberry Pi with a few events. Everything was working well, being able to turn on a few lights with a double click. Now one of the dimmers is not reporting status anymore (I didn't make any change in Homeseer). How can I debug what is happening? I checked on the device web page, and when the dimmer is turned on or off, Homeseer thinks the state doesn't change, and events are not triggered. I checked the log, and don't see any error. What else can I do?
Homeseer WD100+ stopped reporting instant status
GuestTags: None
I have a similar problem, I'm not sure if it's hardware or software based. optimizing the HS-WD100+ switch/dimmer in question solves the problem in my setup.
I suspect this issue also affects my devices that don't report instant status but that wasn't as noticeable as my instant status events not firing. I've had devices not update their status after being manually set, even when being polled regularly, but never tried to trouble shoot them. I think that could be the same issue.HS4 Pro on Shuttle NC10U, Win10; Z-NET
Number of Devices: 1005
Number of Events: 293
Originally posted by ServiceXp View PostTry Killing power to the switch. My first set of dimmers would fail in this mode all the time.
Sent from my ASUS_Z00AD using TapatalkHS4 Pro on Shuttle NC10U, Win10; Z-NET
