Thanks for getting the updates in the updater. I just updated to .43 using the updater but .44 doesn't appear to be there?
Also, I received this error and was forced to restart Homeseer:
Jun-16 8:48:09 AM Plug-In Finished initializing plug-in ISYInsteon
Jun-16 8:48:09 AM Error (2) Unable to initialize interface ISYInsteon :Either no license or trial has expired
Jun-16 8:48:09 AM Updater Re-initializing plugin after update.
Jun-16 8:48:09 AM Updater Install/Update of package ISYInsteon Plugin was successful.
Jun-16 8:48:09 AM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\ISYInsteon\SQLite.Interop.dll
Jun-16 8:48:09 AM Updater Copying file: C:\Program Files\HomeSeer HS3\bin\ISYInsteon\System.Data.SQLite.dll
Jun-16 8:48:09 AM Updater Copying file: C:\Program Files\HomeSeer HS3\HSPI_ISYInsteon.exe.config
Jun-16 8:48:09 AM Updater Installing package ISYInsteon Plugin
Jun-16 8:48:09 AM Updater Update HSPI_ISYInsteon.exe downloaded successfully
Jun-16 8:48:08 AM Updater Downloading update: ISYInsteon Plugin
Jun-16 8:48:08 AM Info Plugin ISYInsteon with instance: has disconnected
Once I restarted Homeseer with .43 installed, the .44 was in the updater.
After installing .44, I got the same error as above and had to restart Homeseer again. This is OK, but I wanted to let you know in case this isn't supposed to happen.
Tim
Tim
