Starting to have some challenges with the bridge. Below is the log from Monday when it seemed to just stop talking to the bridge. I restarted the computer which seems to fix for a while then it slowly stops working again. I have the IP of the bridge reserved so it shouldn't be randomly changing. This log goes on for hours, I just copied a small snip for this question to illustrate what is going on.
Any help or insight would be appreciated.
May-01 11:41:21 PM JowiHue Warning: There was an issue reaching the bridge, will be retrying
May-01 11:29:57 PM JowiHue Warning: IP address 192.168.xxx.xxx reachable, known as ip address for a bridge, but is no longer recognised as bridge....
May-01 10:59:49 PM JowiHue Warning: IP address 192.168.xxx.xxx reachable, known as ip address for a bridge, but is no longer recognised as bridge....
May-01 10:41:21 PM JowiHue Warning: There was an issue reaching the bridge, will be retrying
May-01 10:29:42 PM JowiHue Warning: IP address 192.168.xxx.xxx reachable, known as ip address for a bridge, but is no longer recognised as bridge....
May-01 10:16:09 PM JowiHue Warning: There was an issue reaching the bridge, will be retrying
May-01 9:59:34 PM JowiHue Warning: IP address 192.168.xxx.xxx reachable, known as ip address for a bridge, but is no longer recognised as bridge....
May-01 9:41:21 PM JowiHue Warning: There was an issue reaching the bridge, will be retrying
May-01 9:29:26 PM JowiHue Warning: IP address 192.168.xxx.xxx reachable, known as ip address for a bridge, but is no longer recognised as bridge....
May-01 8:59:18 PM JowiHue Warning: IP address 192.168.xxx.xxx reachable, known as ip address for a bridge, but is no longer recognised as bridge....
May-01 8:41:21 PM JowiHue Warning: There was an issue reaching the bridge, will be retrying
May-01 8:29:11 PM JowiHue Warning: IP address 192.168.xxx.xxx reachable, known as ip address for a bridge, but is no longer recognised as bridge....
May-01 8:12:15 PM JowiHue Warning: There was an issue reaching the bridge, will be retrying
May-01 8:12:08 PM JowiHue Warning: There was an issue reaching the bridge, will be retrying
May-01 7:59:03 PM JowiHue Warning: IP address 192.168.xxx.xxx reachable, known as ip address for a bridge, but is no longer recognised as bridge....
