In 6 Button or 8 Button Dual-Band KeypadLinc Dimmer or Switch there is a missing command from the drop down list under Button Mode. There is Toggle,
Non-Toggle On, but the Non-Toggle Off is Missing!
What I would like to have happen is when Button C is Pressed Toggle Fan On,
then when Button D is Pressed Toggle Fan Off and sync button led's, and the device. I can get Buttons to Toggle on and off correctly when I set Button C and Button D to Toggle and both buttons to Radio Group 1. Then when I add the link I do not cross link I just Link Button-C to on and Button-D to Off, and it works. But when I turn on Button-D via HS3 Device Management the Button D turns On but does not toggle Button C Off, it leaves it on.
Under Firmware Version:43 (7.3) does not have Non-Toggle Off, but it only has these two settings under (Button Mode, Button Groups), HS Control is missing.
Under Firmware Version:41 (6.9) does have the Non-Toggle Off, but it also has these three settings under (Button Mode, HS Control, Button Groups)
The plugin version is 3.0.6.0.
Does anyone have any ideas on this?
Joe.
Joe.
