So, I just changed my old V1 bridge with V2 and now it wont reach my bridge. Looks like it is still trying to reach the old one even though it is removed from the system(via the app).
Do I need to delete some old files or something?
This is what i get from the logs:
May-09 1:13:50 PM JowiHue ============================================================================================== May-09 1:13:50 PM JowiHue 3 Animations available for use in this plugin May-09 1:13:50 PM JowiHue 12 Local scenes available for use in the JowiHue plugin May-09 1:13:50 PM JowiHue 22 Presets available for use in the JowiHue plugin May-09 1:13:50 PM JowiHue -------------------------------------Plugin info --------------------------------------------- May-09 1:13:50 PM JowiHue 1 Daylight sensor found on bridge 'Philips hue' May-09 1:13:50 PM JowiHue 1 Presence sensor found on bridge 'Philips hue' May-09 1:13:50 PM JowiHue 2 Lightlevel sensor(s) found on bridge 'Philips hue' with 2 supporting HS device(s) May-09 1:13:50 PM JowiHue 2 Temperature sensor(s) found on bridge 'Philips hue' with 2 supporting HS device(s) May-09 1:13:50 PM JowiHue 2 Motion sensor(s) found on bridge 'Philips hue' with 2 supporting HS device(s) May-09 1:13:50 PM JowiHue 9 Groups available on bridge 'Philips hue' May-09 1:13:50 PM JowiHue 14 lights connected to bridge 'Philips hue' May-09 1:13:50 PM JowiHue -------------------------------------Bridge info --------------------------------------------- May-09 1:13:50 PM JowiHue ============================================================================================== May-09 1:13:50 PM JowiHue 9 Groups available on bridge 'Philips hue' May-09 1:13:50 PM JowiHue 3 lights connected to bridge 'Philips hue' May-09 1:13:50 PM JowiHue -------------------------------------Bridge info --------------------------------------------- May-09 1:13:50 PM JowiHue ============================================================================================== May-09 1:13:19 PM JowiHue Warning: + Bridge 'Philips hue' is disconnected - IP 192.168.1.4 May-09 1:13:18 PM JowiHue Pressed button for immediate scan for bridges - scanning started May-09 1:13:15 PM JowiHue * Connected to bridge Philips hue at 192.168.1.17 May-09 1:13:15 PM JowiHue * Bridge Philips hue at 192.168.1.4 registered, but not reachable May-09 1:13:07 PM JowiHue Warning: Bridge Philips hue not reachable on 192.168.1.4 is bridge powered on or IP address has changed? May-09 1:12:53 PM Plug-In Finished initializing plug-in JowiHue May-09 1:12:53 PM JowiHue InitIO:Plugin basic initialisation done May-09 1:12:52 PM JowiHue Starting plugin JowiHue 1.1.2.8 on Linux May-09 1:12:50 PM Info Plugin JowiHue has connected. IP:127.0.0.1:58665
