  #21
Old July 17th, 2017, 01:19 PM
jon00's Avatar
jon00 jon00 is offline
OverSeer
The first line of your test1.vb should be:
#Include Includes/functions.vb
NOT
#Includes Includes/functions.vb
Jon
  #22
Old July 17th, 2017, 02:07 PM
donstephens's Avatar
donstephens donstephens is online now
OverSeer
Ah, that is what you were trying to tell me.
Sadly, still no joy, same error message.
Don
  #23
Old July 17th, 2017, 02:13 PM
jon00's Avatar
OverSeer
Have you tried copying my test.vb and functions.vb I posted earlier into yours to see if they work?
  #24
Old July 17th, 2017, 04:22 PM
OverSeer
Yes I did, with the same error messages. Somehow, my system must be set up differently than others, in what way, I haven't a clue.
Quote:
  #25
Old July 17th, 2017, 07:55 PM
sparkman's Avatar
sparkman sparkman is offline
OverSeer
Quote:
Hi Don, have you tried putting the file with the subroutines in the Scripts folder to rule out an issue with the paths? The include statement should look like this then:
#Include functions.vb
Cheers
Al
HS3Pro 3.0.0.318 on Jetway JBC501F9Q-Q87-B i7 8GB 1874 Devices, 955 Events, 28 Plugins
Z-Wave 3.0.1.131 Z-Net 105 nodes:Leviton Vizia,Kwikset,FortrezZ Valve/Sensors,Everspring Sensors/Modules/Outlets,CT30 Stats,MIMOLites,Aeotec Smart Switches
RFXCom W800,RFXrec433,RFXtrx433|APCUPSD|Pushover|Squeezebox|weatherXML|HS Phone W2C|APCUPSD|UltraLog
UltraGCIR GC-100|UltraNetcam|UltraPioneer|Ultra1Wire|DSC PC1832|BLLED|BLTVGuide|ImperiHome|jon00 Utilities|MySensors
PHLocation|X10 CM11A IOLinc,etc
  #26
Old July 17th, 2017, 11:28 PM
OverSeer
Hi Al;
Yeah, just tried it. Same error. I've got to be doing something wrong. Just don't know what.
  #27
Old July 18th, 2017, 04:11 PM
OverSeer
So it turns out that vb.net has no #include statement. Sorry to have wasted everyone's time and thanks for all the suggestions.
  #28
Old July 18th, 2017, 04:26 PM
rmasonjr's Avatar
rmasonjr rmasonjr is offline
OverSeer
Does changing it to "imports" instead of "#include" work?
61 Z-Wave Nodes, 162 Events, 293 Devices
UPB modules via HAI plugin/panel
Plugins: Z-Wave, BLRF, HAI, HSTouch, weatherXML, EasyTrigger
  #29
Old July 18th, 2017, 04:37 PM
OverSeer
Nope, not for me. Seems to work for everyone else .
  #30
Old July 19th, 2017, 08:44 PM
B1Trash B1Trash is offline
Seer
How about using hs.RunScript or hs.RunScriptFunc
https://homeseer.com/support/homeseer...ipts_runex.htm
https://homeseer.com/support/homeseer...scriptfunc.htm
It works for me on my Zee S2. I use it to initialize all my scripts on startup so I don't have to wait for things to compile the first use.
-Jon
  #31
Old July 19th, 2017, 09:52 PM
waynehead99 waynehead99 is offline
Super Seer
Quote:
https://homeseer.com/support/homesee...ipts_runex.htm
https://homeseer.com/support/homesee...scriptfunc.htm
-Jon
I do this as well. Currently I have a script set to control the lights with motions (allows me to only have to create 1 event for each light). I have 2 scripts to do the work, one to control the light, and another to create the delayed event to turn the light off. I run this function and pass the parameters I need from the previous script. I have them split because I wanted to light latency to be very minimal. Works very well.
  #32
Old July 19th, 2017, 10:00 PM
OverSeer
Well, that's one way to do it. i'll give it a try.
HTML code is Off
Error in pops subroutine jono Jon00's plugins and scripts 19 August 12th, 2010 07:49 AM
Common issues rjh HomeSeer Phone 0 January 26th, 2007 04:17 PM
Named subroutine behaves different than "main" dwoolridge Script & Plug-In Development 10 November 22nd, 2004 11:51 PM
Running a subroutine on an ASP from an include Tom Kern Script & Plug-In Development 4 May 14th, 2004 10:30 AM
Exiting a script from a subroutine. RSLoeb Script & Plug-In Development 2 December 17th, 2003 11:46 AM
