UltraMon3 Host Discovery
    Hi Randy,
    I was trying out UltraMon recently (I used to use it under HS2). In the manual it states the following:
    In addition, you can create an event which triggers when the plug-in detects a new host on your network (e.g. UltraMon3 Host Discovery).
    However, I don't see a trigger or other way to do this. Can you point me in the right direction?
    Al
    Hello Al,
    Just populate the values within the following plug-in options:
    Discovered Host E-Mail Notification Options
    Ultrajones
      Thanks Randy, but I was looking to create an event when a new host was discovered. THat's what the manual indicates, but is that not possible? I only see email related fields under that section.
      Al
