Cannot Update Z-Wave Plugin on Linux - Fixed!
    Running HS3 on Linux (an RPI3, actually) I've been unable to update the Z-Wave plugin in quite a while -- I'm on 3.0.194; 3.0.130 is current. Each time I've tried over the last few months I get the message:
    'Install/Update of packages HomeSeer Z-Wave failed.'
    The only log messages I can find are in /var/log/daemon.log. The relevant messages are:
    Sep 9 12:30:57 elms-hs3-01 mono[1603]: 12:30:57:3888:[Updater]->Downloading update: HomeSeer Z-Wave
    Sep 9 12:30:58 elms-hs3-01 mono[1603]: 12:30:58:2291:[Updater]->Update HSPI_ZWave.exe downloaded successfully
    Sep 9 12:30:58 elms-hs3-01 mono[1603]: 12:30:58:2301:[Updater]->Installing package HomeSeer Z-Wave
    Sep 9 12:31:00 elms-hs3-01 mono[1603]: 12:31:00:8330:[Updater Error]->Installation of package HomeSeer Z-Wave failed. Try disabling the plugin first, then re-try the update.
    Sep 9 12:31:00 elms-hs3-01 mono[1603]: 12:31:00:8344:[Updater]->Install/Update of package HomeSeer Z-Wave failed.
    I have disabled the Z-Wave plugin per the hint the log, but that didn't help. The system has even been rebooted with the plugin disabled to make sure the plugin was not running.
    Any suggestions?
    -M.
    Any suggestions?
    -M.
    did you solve this?
    Certified installer for HomeSeer, Control4, KNX and Eaton/xComfort
      Try the following:
      1.Disable the plugin
      2.Restart Homeseer
      3.Install the update
      3.Enable the Plugin
      I have this trouble too sometimes and this works for me.
      Good luck.
      Greig.
      Scripts =
      Various
        Same problem here! This just started recently.
        Dec-07 16:44:49 Plug-In Finished initializing plug-in Z-Wave
        Dec-07 16:44:49 Error (2) Unable to initialize interface Z-Wave :Either no license or trial has expired
        Dec-07 16:44:49 Updater Re-initializing plugin after update.
        Dec-07 16:44:49 Updater Install/Update of package HomeSeer Z-Wave Linux failed.
        Dec-07 16:44:49 Updater Error Installation of package HomeSeer Z-Wave Linux failed. Try disabling the plugin first, then re-try the update.
        Dec-07 16:44:46 Updater Installing package HomeSeer Z-Wave Linux
        Dec-07 16:44:46 Updater Update HSPI_ZWave.exe downloaded successfully
        Current Date/Time: 12/7/2017 4:45:25 PM
        HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.388
        Linux version: Linux HomeTrollerZeeS2 3.18.7-v7+ #755 SMP PREEMPT Thu Feb 12 17:20:48 GMT 2015 armv7l GNU/Linux System Uptime: 0 Days 0 Hours 2 Minutes 56 Seconds
        IP Address: 192.168.1.112
        Number of Devices: 180
        Number of Events: 85
        Available Threads: 399
        HSTouch Enabled: True
        Event Threads: 0
        Event Trigger Eval Queue: 0
        Event Trigger Priority Eval Queue: 0
        Device Exec Queue: 0
        HSTouch Event Queue: 0
        Email Send Queue: 0
        Anti Virus Installed:
        Enabled Plug-Ins
        3.0.1.162: Z-Wave
          Is there a HSPI_ZWave.exe still running on the system?
            running on .162, but as others posted unable to update
            tried disabling plugin and tried to go back to release version but can't.
              Did you restart after disabling it?
              Greig.
              Scripts =
              Various
                yes, several times thanks for the response
                  Just to be clear, you need to disable the plug-in, shut down HomeSeer and restart the computer, not just HomeSeer . The problem is with the O/S locking the executable. Restarting the O/S with the plug-in disabled releases the executable and allows the new one to be installed.
                    Thanks, but same issue
                    Disabled plugin, told HS to shut down, waited until no leds flashing, unplugged Zee, waited 30 secs, went into HS again, Zwave plugin still disabled, tried to update and:
                    Dec-08 08:39:21 Updater Install/Update of package HomeSeer Z-Wave Linux failed.
                    Dec-08 08:39:21 Updater Error Installation of package HomeSeer Z-Wave Linux failed. Try disabling the plugin first, then re-try the update.
                    Dec-08 08:39:18 Updater Installing package HomeSeer Z-Wave Linux
                    Dec-08 08:39:18 Updater Update HSPI_ZWave.exe downloaded successfully
                    Dec-08 08:39:18 Updater Downloading update: HomeSeer Z-Wave Linux
                    Dec-08 08:39:18 Updater Starting download of updates
                    I've done this before that's how I got .162 installed.
                    Thanks for your help here!
                      HS ADMIN Please take a look! - Got it working
                      There is something broken in recent updates.
                      I SSH'd into Zee and found the ZIP file going into the ZIPS directory but they weren't getting UNZIPPED. I tried manually unzipping but got a PERMISSIONS error. Entered command SUDO unzip ZWave "x'.zip from Updates3 and got all the files, Then I manually copied the new ZWave.exe file to the HomeSeer folder and restarted and HS found the new .exe.
                      Current Date/Time: 12/11/2017 5:12:20 PM
                      HomeSeer Version: HS3 ZEE S2 Edition 3.0.0.368
                      Linux version: Linux HomeTrollerZeeS2 3.18.7-v7+ #755 SMP PREEMPT Thu Feb 12 17:20:48 GMT 2015 armv7l GNU/Linux System Uptime: 0 Days 0 Hours 11 Minutes 45 Seconds
                      Number of Events: 87
                      Enabled Plug-Ins
                      3.0.1.165: Z-Wave
                        Thanks, not really sure what is going on there but will investigate.
                        We did just post a beta, build 393, can you update your zee to 393 and see if the issue is still there? When I tried to update to the latest zwave plugin it updated ok on 393.
                        Enabled Plug-Ins
                        3.0.1.165: Z-Wave
                          There was a problem with the Linux install of the plugin, this has been fixed in build 3.0.1.173 or later.
                            Build 3.0.1.173 of the plugin or of HS3 itself?
                            -M.
                              -M.
                              Disregard -- I just got confused for a moment there. :-)
