I read your strong suggestion that we "make a backup of your insteon.ini and homeseer database before upgrading." I cannot find the insteon.ini. I can get into the linux tools and run an "ls -l" and thus obtain a files list. I am unable to change directories at all. I really need some guidance as to how to conduct this routine using the "Linux Tools" that are part of my menu when i use Google Chrome to log into my Home Seer device which is the " HS3 ZEE S2 Edition 3.0.0.368".
Here is the listing I obtain from the "ls -l" command:
total 38380
-rwxr-xr-x 1 homeseer root 77 Mar 26 2015 autostart_hs
drwxr-sr-x 11 homeseer root 4096 Jan 1 17:03 bin
-rwxr-xr-x 1 homeseer root 271 Mar 26 2015 change_password.sh
-rwxr-xr-x 1 homeseer root 35310 Aug 24 2015 check_passwd
drwxr-sr-x 3 homeseer root 12288 Jan 5 11:38 Config
drwxr-sr-x 2 homeseer root 4096 Mar 26 2015 ConfigBackup
-rw------- 1 root root 27979776 Jan 3 09:06 core
drwxr-sr-x 6 homeseer root 4096 Jan 5 11:01 Data
drwxr-sr-x 3 homeseer root 4096 Dec 23 13:42 Docs
-rwxr-xr-x 1 homeseer root 683 Mar 26 2015 factory.sh
-rw-r--r-- 1 root root 70656 Aug 4 2012 FTD2XX_NET.dll
-rwxr-xr-x 1 homeseer root 54 Mar 26 2015 go
drwxr-sr-x 2 homeseer root 4096 May 16 2016 Grammar
-rw-r--r-- 1 root root 1073152 Aug 1 13:39 HAI.Controller.dll
-rw-r--r-- 1 root root 17 Nov 28 2016 HarmonyHub.AuthorizationToken
-rw-r--r-- 1 homeseer root 76288 Sep 25 09:59 HomeSeerAPI.dll
-rwxr-xr-x 1 root root 37376 May 16 2016 HS3SentryLinux.exe
-rw-r--r-- 1 homeseer root 44032 Mar 26 2015 HSCF.dll
-rw-r--r-- 1 homeseer root 13312 Sep 25 09:59 HSConsole.exe
-rw-r--r-- 1 homeseer root 1518 Jul 19 13:05 HSConsole.exe.config
-rw-r--r-- 1 root root 305664 Jul 27 17:31 HSPI_BLDenon.exe
-rw-r--r-- 1 root root 49664 Oct 5 2016 HSPI_CM15A.exe
-rw-r--r-- 1 root root 209408 Dec 15 2016 HSPI_HarmonyHub.exe
-rw-r--r-- 1 root root 50176 Nov 26 2014 HSPI_HSInsteon.exe
-rw-r--r-- 1 root root 352 Jan 16 2014 HSPI_HSInsteon.exe.config
-rw-r--r-- 1 root root 221184 May 29 2015 HSPI_HSTOUCH.exe
-rw-r--r-- 1 root root 93696 Oct 4 16:05 HSPI_Insteon.exe
-rw-r--r-- 1 root root 909824 Dec 10 01:08 HSPI_MyQ.exe
-rw-r--r-- 1 root root 4784 Dec 10 01:08 HSPI_MyQ.exe.config
-rw-r--r-- 1 root root 507904 Sep 26 09:49 HSPI_OMNI.exe
-rw-r--r-- 1 root root 355 Aug 1 13:54 HSPI_OMNI.exe.config
-rw-r--r-- 1 root root 145920 Jun 8 2016 HSPI_SAMPLE.exe
-rw-r--r-- 1 root root 195072 Oct 17 20:21 HSPI_SKWARE_HW_WIFI_TSTAT.exe
-rw-r--r-- 1 root root 1746 Jul 11 08:23 HSPI_SKWARE_HW_WIFI_TSTAT.exe.config
-rw-r--r-- 1 root root 223744 Apr 21 2015 HSPI_UPB.exe
-rw-r--r-- 1 root root 354 Nov 26 2013 HSPI_UPBSpud.exe.config
-rw-r--r-- 1 root root 3136512 Dec 28 10:23 HSPI_ZWave.exe
-rw-r--r-- 1 root root 357 Dec 18 2012 HSPI_ZWave.exe.config
drwxr-sr-x 15 homeseer root 4096 Dec 23 13:42 html
-rwxr-xr-x 1 homeseer root 36 Mar 26 2015 install.sh
-rw-r--r-- 1 root root 553472 Oct 4 16:05 Insteon.dll
-rwxr-xr-x 1 homeseer root 408 May 16 2016 led.sh
drwxr-sr-x 2 homeseer root 4096 Jan 5 10:10 Logs
-rwxr-xr-x 1 homeseer root 930816 Mar 26 2015 Mail.dll
drwxr-sr-x 2 homeseer root 4096 Jul 5 2017 Media
drwxr-sr-x 2 homeseer root 4096 Dec 24 06:54 mochad
-rwxr-xr-x 1 root root 606 Aug 24 2015 password_check.c
-rwxr-xr-x 1 homeseer root 22 Mar 26 2015 play_audio.sh
-rwxr-xr-x 1 homeseer root 488 Mar 26 2015 register_with_find.sh
-rwxr-xr-x 1 homeseer root 390 Aug 30 10:45 restart.sh
-rw-r--r-- 1 root root 126976 Dec 10 2012 RssToolkit.dll
-rwxr-xr-x 1 homeseer root 14 Mar 26 2015 run_command_raw.sh
-rwxr-xr-x 1 homeseer root 43 Mar 26 2015 run_command.sh
-rwxr-xr-x 1 root root 2849280 Sep 25 09:59 Scheduler.dll
-rw-r--r-- 1 homeseer root 1596 Sep 25 09:59 Scheduler.dll.config
drwxr-sr-x 2 homeseer root 4096 Dec 23 13:42 scripts
-rwxr-xr-x 1 homeseer root 405 Mar 26 2015 shutdown_controller.sh
-rwxr-xr-x 1 homeseer root 31 Mar 26 2015 shutdown.sh
-rwxr-xr-x 1 homeseer root 38 Mar 26 2015 speak.sh
-rwxr-xr-x 1 homeseer root 32 Mar 26 2015 speak_to_file.sh
drwxr-sr-x 2 homeseer root 4096 Jul 5 2017 temp
drwxr-sr-x 2 homeseer root 4096 Mar 26 2015 Temp
-rwxr-xr-x 1 homeseer root 195 Mar 26 2015 updatehs.sh
-rw-r--r-- 1 root root 56988 Jun 17 2016 updater.txt
drwxr-sr-x 3 root root 4096 Jan 5 10:11 Updates3
-rwxr-xr-x 1 homeseer root 493 Mar 26 2015 update.sh
drwxr-sr-x 3 root root 4096 Dec 23 13:42 usr
drwxr-sr-x 2 homeseer root 4096 Mar 26 2015 Wave
drwxr-sr-x 2 homeseer root 4096 May 16 2016 wave_files
total 38380
