Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Z-Wave Plug-in
HomeSeer Z-Wave Plug-in Discussions relating to the Z-Wave plug-in
Old August 4th, 2017, 02:08 AM
wanaka wanaka is offline
Seer
Fibaro Relay 2 x 1.5kw module
I have included a fibaro relay 2 x 1.5kw module. I don't seem to be able to see the status. it is remained unknown. I can on and off both switches without any issue though.
Old August 4th, 2017, 04:18 AM
akurz akurz is offline
Seer Plus
Hi Wanaka,
Which Z-Wave plugin version are you running?
That's definitely a communication issue of some sort. Even though it's a Gen5 device just try a couple of full optimize. That sometimes helps by sorting out the routing table. If that doesn't help, delete all devices for this switch except the master device and run a Rescan.
I can see from the devices created that this is a version 3.x firmware, so your associations should be
Group 2 - Homeseer (ID: 1)
Group 4 - Homeseer (ID: 1)
This is enough for switch functionality. Optionally (only needed if you want to use this switch to control a multilevel device like a dimmer or shutter) add
Group 3 - Homeseer (ID: 1)
Group 5 - Homeseer (ID: 1)
Group 1 (life line) doesn't work at all with HS (in my experience)
Alex
Old August 4th, 2017, 04:21 AM
Seer Plus
This is one of mine as example:
Old August 4th, 2017, 04:29 AM
Seer Plus
Another odd thing here is that the status for the two switches is unknown, but they seem to have been set at some point. Can you check the "Advanced" tab in the device settings for one of the Switch Binary? Should look something like this:
Old August 4th, 2017, 05:48 AM
Seer
I am running plugin version 3.0.1.130
Old August 4th, 2017, 06:07 AM
Seer
it look I can only associate
group 1 to end point 1
group 2 to end point 2
I try different combination it doesn't work at all for example group 2 1 endpoint is ok but group 4 2 endpoint it won't add at all.
Old August 4th, 2017, 06:08 AM
Seer
by the way what is this error Error getting Z-Wave device Firmware Update UI: Method 'ZWave_Company.ZW_Company.NameShort' not found.
Old August 4th, 2017, 08:34 AM
Seer
I reset the zwave plugins remove and add it back to clear the error.
As for the status update issue I resolve it by only having group 3 associate to homeseer and yes it get update when I on and off the button
Old August 4th, 2017, 08:49 AM
Seer
That is another problem now if someone go and push the physical switch, the switch multilevel 1 get update instead..very annoying
Old August 4th, 2017, 10:32 AM
Seer
Now the status get updated but I still have the following issue.
When i click the study fan or study light the status get update to show whether it is on or off.
However if someone go and push the physical button the switch multilevel 1 get update but not the study fan.
Old August 11th, 2017, 06:15 PM
Seer Plus
Hi Wanaka,
I know all of the symptoms you describe. I've seen all of them and they were always related to associations. What are your associations looking like right now?
Cheers,
Alex
Old August 12th, 2017, 12:03 AM
Seer
i have only associated group 2 and 4 to homeseer. The only way to solve this stupid issue is I have to link multilevel 1 to binary 1 then the switch status will update correctly. When someone push the physical button multilevel 1 will trigger binary 1 status to reflect correctly.
No sure whether this is the right way but since support also has no reverted anything from the past few days so I just try to work around by doing that
HTML code is Off
Fibaro double relay gd1210 HomeSeer Z-Wave Plug-in 7 October 3rd, 2016 06:53 PM
Fibaro Relay Switch 2x1.5kW Issues smokeycoles HomeSeer General Discussion Area 18 April 19th, 2016 01:40 PM
Fibaro relay question kriz83 HomeSeer General Discussion Area 2 February 6th, 2016 05:27 AM
fibaro relay dukspi Lighting & Primary Technology Discussion 4 December 26th, 2015 07:56 PM
Fibaro double relay switch theendisnye HomeSeer Z-Wave Plug-in 27 April 23rd, 2015 12:47 PM
